 Tower Trainer .40 cg >
Old 07-24-2004 | 08:54 PM
Default Tower Trainer .40 cg
Could somone give me the cg on the tower trainer .40? Thanks, don't know what I've done with the instruction book.
Old 07-24-2004 | 09:13 PM
bubbagates's Avatar
My Feedback: (32)
Default RE: Tower Trainer .40 cg
F-16,
I believethis may be the link to download the manual for that plane
http://www.towerhobbies.com/products/pdf/towa21mnl.pdf
If not just search around Tower hobbies web site. you can usually download their manuals from it. In fact all but SIG have their respective manuals avaible for download
Bill
bingo field's Avatar
http://www2.towerhobbies.com/cgi-bin...?&I=LXCAS2&P=0
SPECS: Wingspan: 62" (1575mm)
Wing Area: 698 sq in (45sq dm)
Wing Chord: 11.25" (285.75mm)
Weight: 5 lb (2268kg) assembled
Wing Loading: 17 oz/sq ft (52g/sq dm)
Fuselage Length: 51.5" (1308mm)
Airfoil: Flat Bottom High-Wing
*Center of Gravity: 3-1/2" (89 mm) Back from the wing's leading edge
at the fuselage
Control Throws- High Rate Low Rate
Elevator: Up & Down 1/2" (13mm) 3/8" (9.5mm)
Rudder: Right to Left 1" (26mm) 1" (26mm)
Ailerons: Up & Down 5/8" (16mm) 1/2" (13mm)
Width of fuselage- 3 3/8"
Old 07-24-2004 | 10:24 PM
DOH!! Sorry....thanks for the info.
