 hangar 9 alpha >
hangar 9 alpha
hangar 9 alpha
Old 10-03-2004 | 10:07 AM
Default hangar 9 alpha
i have a small problem i read it on hear a little while ago and now i cant find the post to convert my plane to a tail dragger i have the landening gear and tail wheel just not sure how to go about it
Old 10-03-2004 | 11:43 AM
MinnFlyer's Avatar
Default RE: hangar 9 alpha
Basically, you need to add a 1/4" plywood plate (about 1/2" wider front to back than the gear) and brace it with 1/8" ply on each side. Tri stock in the corners is a good idea too.
Place them so the wheels line up aprox with the LE of the wing
Old 10-03-2004 | 11:58 AM
how whould you go about doing the tail wheel the elevator is in the way to hook direct to it
Old 10-03-2004 | 01:07 PM
bingo field's Avatar
http://www.rcuniverse.com/forum/m_21..._1/key_/tm.htm
Read this, it should cure things up some, with pictures.
Old 10-03-2004 | 01:48 PM
thanks for the site but it will not let me click on the pics to inlarge them i am still lost on how to make the tail wheel work
Old 10-03-2004 | 07:09 PM
dvs i know what you are talking about cause i have the same problem. i think what im gonna do is mount a servo about 6 -10 inches from the rear of the plane to control the tail wheel and hook it up with an extension and Y harness ...right now that seems like the easiest solution. That means i'll have an extra servo on the plane but that shouldn't cause any problems considering i have a .68 engine in it now.All i have to do now is buy a Y harness, servo and extension and hook it all up.
Old 10-03-2004 | 07:31 PM
You use the rudder servo, just like the nosegear did, but you run the pushrod to the opposite side of the fuselage from the rudder pushrod, I used a nylon tube to run the rod in. Here is the picture.
Old 10-03-2004 | 08:20 PM
bingo ..did you have to bend the rod for the tail wheel?...it looks like it's at a wierd angle coming out of the fuselage
Old 10-03-2004 | 08:44 PM
Once you push it through, just put a little offset in it (like for the throttle) to compensate for the angle it comes out of the fuselage from, to the more direct angle for the z-bend to push the wheel (steering) in.
