 4* covering help!!! >
4* covering help!!!
4* covering help!!!
Old 10-21-2004 | 08:50 PM
Default 4* covering help!!!
ok I am finally to covering my 4* 40 and I have the wing tips done but now I am to the torque rod blocks and it is getting agrivating I can't seem to figure out how to go about covering these and the wing hold down plates, can anyone help
RonH
Old 10-21-2004 | 09:28 PM
Default RE: 4* covering help!!!
Do you mean the dowels? If you are, on my 60 i just put a strip of covering between the dowels and then covered the top and bottom of the wing, if theres a little wood showing near the dowels is ok that parts gonna be inside the fuse or you can patch it up with scraps. When I cover I like to use trial and error.
John
Old 10-22-2004 | 08:19 AM
jettstarblue's Avatar
Try two things: Use little pieces of covering, and cover it bit by bit, or do your best, and seal it from fuel with some epoxy, or paint.
Give us a little more info, not sure exactly what you mean. You mean the plywood? The step in the ply, or?
Old 10-22-2004 | 09:15 AM
I am talking about on the Trailing edge where the aileron wire and blocks are, I dont want it to look crapy but it seems hard to get between the wires thanks
Ron
Old 10-22-2004 | 10:50 AM
MinnFlyer's Avatar
This gets a little tricky, but it's not hard. You want to do it in pieces. Here are some pics that will save me a lot of typing.
ID:	185373   Click image for larger version
ID:	185374   Click image for larger version
MinnFlyer's Avatar
And for the bolt plate:
ID:	185376   Click image for larger version
ID:	185377   Click image for larger version
ID:	185378   Click image for larger version
