 hovering? >
hovering?
hovering?
Old 11-05-2004 | 05:09 PM
Default hovering?
Hey guys,
Please give me all the tips and how tos you can about hovering. I have no intension of tryin to hover my trainer but I want to try and learn on rf g2. Im using the GP Cap 232 on RF. thanx
Old 11-05-2004 | 05:18 PM
tychoc's Avatar
Default RE: hovering?
Not specifically about hovering, but check out:
[link=http://www.horizonhobby.com/Explore/Article.aspx?ArticleID=1322]3D[/link]
[link=http://www.horizonhobby.com/Explore/Article.aspx?ArticleID=1044]Torque Rolling[/link]
Old 11-07-2004 | 12:09 AM
a good entry, lots of control surfaces, quick reaction, and alot of knowledge as to what the plane is going to do. trainers won't sustain a hover no matter how much engine you throw at them, they don't have the control surfaces needed.
Old 11-07-2004 | 12:36 AM
ICE_MAN's Avatar
Smoking Crater... How long Is sustaining a hover for you? My Superstar with sT 51 will ower 5-10 sec. and the pull out..
Old 11-07-2004 | 06:30 PM
aerobatixkid's Avatar
My avistar is on maximum throws with an la 40 swinging an apc 10x6 and will hover, more less torque roll for about 5 seconds then I let it fall off........... Should use my 46ax but I am saving it for my extra 300.
Old 11-07-2004 | 08:58 PM
depfife's Avatar
My Feedback: (14)
http://www.rcuniverse.com/forum/tm.asp?m=566133
Click on the above link for a thread with some good info.
http://www.blaineaustin.com/3d_tips.htm
Blaine Austin also has some good info about 3D on his site. Nothing specifically on hovering, but still worth a read.
Eric
Old 11-07-2004 | 11:47 PM
a controlled hover that you can enter and exit at will, at least in my book 30 seconds+, but you need a plane capable of sustained hover. 5-10 seconds and you aren't controlling the plane in the hover, it just happens to stay there because of inertia. keep it there 30 seconds and that would be hovering.
I can put my mini IFO vertical, hang it on the prop, but i don't consider that a hover. No rudder on it and it starts to get away from in usually 10-15 seconds max.
Old 11-08-2004 | 12:12 AM
scolpit's Avatar
It is not your problem. RF G2 is a really bad 3d simulator. I can't hover on G2 more than 10 seconds. Don't worry, at the field is much easier... If u want to train hovers on a simulator buy aerofly pro, it is really good simulator, even in 3D situations. I heard that Reflex simulator was a excellent physics simulator, but i never tryed it. But i personally have G2 and aerofly pro! and i can guarantee that aerofly pro is much better(in everything)... well, u dont have races, and try to pass between 2 points... but... who cares?
Try to download aerofly pro videos from http://www.aeroflypro.com/ and see what im talking about
Old 11-08-2004 | 08:30 AM
smokingcrater -- I can hover both of my old Hobbico Superstars -- but they don't torque roll very well -- eventually falling out. Just takes practice.
Old 11-08-2004 | 09:13 AM
The most realistic, and easiest, plane on RF G2 is the Biplane. You have to create a copy and then I went in and moved the CG back about .5 to .7 inches. It isnt like the real thing, but you can learn the basics.
byrdman
Old 11-08-2004 | 09:44 AM
scolpit's Avatar
You right Byrdman, i can hover sucessfuly only with biplane (well, max 10sec). i never tryed to put CG back, but 3d maneuvers on g2 are so bad! they have a lot of work to do about physics!
Old 11-08-2004 | 04:37 PM
Iv tried to make a copy of the bipes but every time i do it says that its not read or something and i can fix it by gettin on explorer? anyone know what its talkin about?
