 brushed Vs. brushless >
Old 04-08-2005 | 06:01 PM
zachj1212's Avatar
Default brushed Vs. brushless
Hi. My name is zach, and i am a happy owner of the aerobird challenger. I am ready to move on, and this is what i think that i am going to get.
Jr-xp6102
wattage cessna 182
Now, i need to dicide if i am going to put in a brushed or brushless moter. I don't have unlimited money, but i CAN afford a speed controler/engine, if i have to. i am 13. Please tell me advantages/disadvatages, and feel free to state your opinion.
Also, do you recomend a different cessna than the wattage?
thanks
zach
Old 04-08-2005 | 06:10 PM
Default RE: brushed Vs. brushless
You probably want to go over to the electric/parkflyer forums with this but I would go with GWS and I have had both them and Wattage planes,,dont worry about brushless motors at this point,,wait until you are a better flyer and want something more aerobatic, its too expensive for a trainer foamy plane...Rog
Old 04-08-2005 | 06:13 PM
exeter_acres's Avatar
Brushless ROCKS.....but I may have to agree....
it really isn't needed for a Cessna (and it ain't cheap!!)
I think the Cessna would fly just fine with a brushed setup.....
now if you think of going for some sort of 3D setup down the road... brushless is the only choice.....IMHO
Old 04-08-2005 | 08:11 PM
zachj1212's Avatar
first, people keep saying that this plane is foam, but it is not. it is all balsa. If i can get a 400 brushless/speedcontroller for 40 buks, them what do u think?
Old 04-08-2005 | 09:16 PM
visit hobby-lobby.com
look at the brushless motors they got there
how much the plane weighes is in consideration on the size 300 or 400 sounds like a good size...
if you concerned about prices so much stay with a brushless motor for half the price...
Old 04-08-2005 | 09:41 PM
zachj1212's Avatar
mabe u guys are looking at the wrong plane. wattage sells two modern cessnas. A trainer/fomie, and this. http://www.globalhobby.com/public/wa...ery/128393.asp this is the one i am looking at. all balsa!
Old 04-09-2005 | 02:11 AM
aeajr's Avatar
If you can get a 400 class brushelss and speed control that are appropraite for this plane, get it. Brushless will be more efficent and typically run longer on the same battery. Can also be more powerful for the same current draw.
Where did you see a combo for $40?
Old 04-09-2005 | 09:50 AM
Campy's Avatar
ORIGINAL: zachj1212
If you have a brushless motor, Buy it. If it is the motor and ESC, try not to break your arm getting your wallet out.
Also let me know where they are for this price as I would like to get a couple for myself.
Old 04-09-2005 | 01:04 PM
sorry guys! but the400 with speedcontroller is not on the market. a flying friend is offering it to me, to help me start out.
Old 04-09-2005 | 06:17 PM
zachj1212's Avatar
wait the post above from chris 101 is from m. i was on a friends comp. oops!
Old 04-09-2005 | 08:58 PM
Maybe I'm going blind but I couldn't see where it said ( wood) anywhere on that website. Says fuse is moulded. Usually that means foam. If your learning to fly your better off with foam anyway. A bit of 5 min epoxy and your back in the air. Not so with balsa.
Old 04-10-2005 | 11:11 AM
zachj1212's Avatar
i see your reasoning, but my flying friend has 2 of them, and i have held them, and watched him work on them, and they are balsa! these words came from his mouth about 4 thursdays ago "this plane is made from balsa, wich is more durable thatn u would think" i will check again today, becasue i am going to his house to convert the white pos clips, to dean plugs.
i will give u an update soon!
Old 04-10-2005 | 06:28 PM
Grab the brushless too. You wont be sorry. Later on you may want to go Lipo batts and they are much more compatible than brush type motors.
Old 04-10-2005 | 07:06 PM
rusirius's Avatar
ORIGINAL: zachj1212
Your friend may THINK it's balsa, but either it's not, or that link isn't the same plane your friend is flying... Flypaper is right about the "molded" fuselage.... That's what "molded" means... molded from plastic or foam... Also, note the control surfaces are corrugated? Corrugated Balsa trees are EXTREMELY rare and very hard to find... [sm=bananahead.gif]
Edit: Ahhh, did more research... The WING is built up from balsa... Not the rest of the plane...
Old 04-10-2005 | 09:44 PM
zachj1212's Avatar
yah. the fuse is plastic, and the tail, wing, is balso. You seem to have a pretty grim look at this plane, so is there another cessna that u recomend?
