School project budget plane
#76
ORIGINAL: TehArrow
the paper and most of the presentation are gunna be on the dynamics of air planes themselves. etc how they create lift, what flaps do what, and probly a journal of the progress.
Just make sure to check out GWS's suggestions on prop sizes on the gear boxes... You don't want to over do things and burn up the motor, although they are cheap.
http://www.gws.com.tw/english/produc...em/eps400c.htm
--Scott
#77
http://www.grc.nasa.gov/WWW/K-12/airplane/bga.html
http://www.ae.su.oz.au/aero/aerodyn.html
http://www.cdli.ca/CITE/flightsc.htm Probably the best for what you are doing
http://www.hpedsb.on.ca/sg/quinte/fl..._of_flight.htm
http://www.ucmp.berkeley.edu/vertebr...t/physics.html
There are a lot more, but these should give you enough info for anything you need.
#78
NJ
http://www2.towerhobbies.com/cgi-bin...?&I=LXHCL0&P=7 would this be to much to handle?
i really want something that can hit 20. since its electric i can tone the throttle down and fly it towards its minimum speed for a while right?
#79
How does the speed of the model effect your report presentation? A lot of experienced people have tried to provide you with a plan that will allow you to accomplish your stated goal(s) of being able to perform a flying R/C model demonstration in less then 2 months. Why is it that you continue to look for models that can and will make accomplishing that goal harder and possibly more dangerous.
BTW Did you ask your teacher IF it you would even be allowed to perform this demonstration on school grounds?
#80
My Feedback: (12)
ORIGINAL: TehArrow
#81
NJ
the teacher actually reccomended the idea.
i was running low on things and she knows im into engineering and physics etc.
i look at 4mph and i just dont see anything special.... up down side to side at a slooooow speed for a big'ish plane.
plus i like challenges . i want to be able to impress myself at the end too
edit: by tonight i hope to have everything ordered
#82
#84
NJ
well if someone could reccomend me a good 15-20 mph electric for a beginer ill be all over it.
building will take to much time appparently
edit: do they make 15-20mph 4 channel electrics? im guessing not arf
#85
Is it just me, or is this thread becoming a collosal waste of time for all of those experienced members who have given good advice?
Even a slow stick will take all of the remaining time you have to learn. Better get started.
Good Luck!!
Good Luck!!
#86
NJ
its not a waste of time if tonight is my deadline and i want to exhaust all POSSIBLE choices. if its a waste of time for you then dont respond.... they obviously are kind enough to answer all my questions and sort through the options
#87
NJ
Might i ask, where is Westfeild? I know of several clubs in NJ, so if you are in the neighborhood, you could get some help.
The only trainer I know of that might go near that speed is http://www2.towerhobbies.com/cgi-bin...=LXJKU3**&P=ML but it is probably too big to fly out of a football feild (atleast the glow version is)
#89
NJ
that plane does look out of my league lol
westfield is about 15 minutes from menlo park mall..
if i could get that electric trainer and then find a club near me that would be awesome.
#92
NJ
if any of you wanna argue stuff out with me through messanger(would be faster and easier) my aol sn is " teharrow "
science ill send you a video of the perfectly excuted flying done by me
#95
http://www2.towerhobbies.com/cgi-bin...?&I=LXGVZ3&P=0
Its electric, 4 chan, and would be an ok starting bird, but LISTEN CLOSE. Its not something you can go fly yourself right out of the box. You will have to have someone train you. You need to find someone that can hook you up with a buddy box and work with you. You will be able to take it and show it to the class, but DO NOT fly it in front of them. You stand a high chance of crashing it into people and hurting someone. Don't take the risk.
Your wasting your time with the egg carton flyers. Just my personal opinion, but they fly slow, go up and down a tiny bit, and will not do anything like a loop or a roll. My tiger moth would, but the wings flexed a ton and almost broke, but I built things into the wings to keep them together.
If you are going to do it, do it right and do it safe.
#97
the wings on the GWS planes are the same as egg cartons. They are thin foam and the plane will not do much, but fly striaght and that is probably more of what you should be getting, but it isn't what you want, and I think it will be a waste of money for you in the long run. Just my 2 cents
#98
Leave the poor kid alone and let him get the GWS stick, at leasts he can get it in the air..once you get the radio gear and complete your assignment, then you can put that equipment (servos,battery,esc,) you in any other plane you want there are lots of parkflyers that are less than $50 .....this part is just for my own fun..dont waste your time and money on a .40 glow trainer that you'll be bored with in no time
#99
i feel so left out... no one repeatedly quoted me :-(
good luck with the ultra stick. thoug take a look at SPADS, i conpleatly forgot about those.
#100
balsa - i like the spads idea for a senior project as well... it's got all the right elements, build from scratch, durable and definitely faster than 15-20. but it's dangerous, too.
if you are settled on an ARF, i suggest the multiplex easy star as the best bet for numerous reasons
1. it's safe since it's foam and the propeller is in the rear out of harms way
2. it's big and easy to see in the air and glides well
3. it's so darn easy to fly. if you've driven an RC car, i can almost guarantee that you can fly the plane given a huge huge huge field and the first flight with someone with experience
4. the RTF takes 30 minutes to put together with 20 of it making sure the stickers are in the right place. and since you do absolutely nothing that determines the performance of the plane, there's absolutely nothing to screw up!
5. it comes RTF or ARF depending on you
6. it's fairly durable and easy to repair
7. you can modify it
i would recommend the following:
easy star kit $60
20amp esc - $25-$30
futaba 4YF with 4 Servos - $120
batteries 8-Cell 9.6V 4/5SC 2000mAh NiMH - $25 (2) - $50
half decent peak charger - $30
grand total - $285
sounds like a lot compared to the $175 RTF price but it's well worth it.
after making it, you fly it with the three channel set up first then you can modify it with larger elevator and larger rudders. then you can cut out ailerons and install an additional servo in for full 3 axis control
another one i'd look at is the sky scooter, which is a little more challenging but faster and more acrobatic.
yes the slow stick is nice, too... but i'd for the SPAD for a challenge and the Easy Star for a lot more fun.
easy star kit $60
20amp esc - $25-$30
grand total - $285
