 SERVO QUESTION for Futaba 7CAP >
Old 04-18-2005 | 04:56 PM
Default SERVO QUESTION for Futaba 7CAP
Hello,
I'm currently building my Top Flite P-51 Gold Edition, and am in need of a new radio set. I'm looking at the Futaba 7CAP 7 channel radio. (This would be a big upgrade over my current Futaba 4 channel Attack.
Does anyone have any comments/experience with the Futaba 7CAP 7 channel transmitter (w/ digital servos)?
Thanks much!
Joe
Old 04-18-2005 | 05:32 PM
IBrakeForNobody's Avatar
My Feedback: (16)
Default RE: Futaba 7CAP question
The Futaba 7CAP is a excellent radio IMO. Its kinda hard to program at first but once you get the hang of it, there are tons of features. Also, if this is a radio you are gonna have for a while, you might want to consider the [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGAF5**&P=ML]7CHP[/link]. Its identical to the 7CAP but there is also heli programing, and they are the same price.
Hope this helps
Old 04-18-2005 | 07:58 PM
I started using one last year with the S3004s. Great radio. It was one of the best RC buys I have ever made.
Old 04-18-2005 | 08:03 PM
One of my best RC buys too. I think the 7cap is a breeze to program. I love the dial feature. The radio has all kinds of fun features. I'm very happy with mine.
Old 04-18-2005 | 08:55 PM
MemoryJack's Avatar
I've been using the 7CAP for about 6 mo. I am very happy with it and I feel like it will be a long time before I need a 9
chan radio. I also like the programming interface.
If I have any complaint, it's that the JR radio's I have handled seem to be a bit more "solid", or better constructed.
Old 04-19-2005 | 03:23 PM
I also have a 7cap and I really like it. Keep the manual around. The radio is loaded with features and you cant remember them all. And to tell ya the truth, I really don't think there is anything wrong with any newer radio. I would only have to say that get as many channels as you can afford cause you will always be one short. That is what all the experienced fellas told me at the field.
Old 04-19-2005 | 04:25 PM
Rubberduck's Avatar
ORIGINAL: IBrakeForNobody
Hope this helps
Does the 7CHP have a ratcheting throttle stick?
Old 04-19-2005 | 04:45 PM
Pilot Chad's Avatar
I am also planning to get the 7C I am gonna get the cheap one though. What is the difference ebtween Not being PCM? Thanks
Chad
Old 04-19-2005 | 11:29 PM
Rubberduck,
The 7CHP has the smooth throttle. I picked one up a while back, and I never intend to fly helis. I must say, I really like the smooth throttle... but... of course everybody will have their preference. The only other mechanical difference in the two models is the CHP has the three position switch on the left side, and the trainer switch on the right side- which is opposite of the CAP
My first computer radio... and I am kicking myself for not doing it sooner.
-Pat-
Old 04-19-2005 | 11:34 PM
zachj1212's Avatar
can you get the 7c with micro things?
Old 04-20-2005 | 10:43 AM
Wrig0335,
When you say 'smooth throttle' do you mean that the throttle stick doesn't 'click' into place?
joe
Old 04-20-2005 | 10:44 AM
also,
what's the truth about digital servos and pcm? If I go with the Futaba 7ch, is it really worth it to upgrade to PCM and digital servos?
Joe
Old 04-20-2005 | 11:40 AM
Bax
The Futaba 7CA (airplane) and 7CH (heli) have identical software. The only difference is that the heli transmitter has a non-ratcheted throttle stick, and the toggle switches are moved around to suit the majority of heli fliers. Both transmitters, though, have the same airplane and heli programming functions. The model type, airplane or heli, deterines the default type when the memory's reset or upon initial power-up.
Old 05-15-2005 | 03:14 PM
I have another ques regarding this radio. I noticed that the PCM version comes with (4) digital S3151 servos. I'd need an additional 3 servos to complete my build. Tower Hobbies doesn't have any S3151's in stock, and wont have them until late june. Is it possible for me to purchase the 7cap with (4) digital servos, and then purchase (3) "standard non-digital S3004" servos? Can I safely mix the standard servos with the digital servos on the same system?
Old 05-15-2005 | 03:56 PM
My Feedback: (16)
Default RE: SERVO QUESTION for Futaba 7CAP
The S3004 servos are single BB digital servos but they have slightly different preformance.
Here are the specs from TH for the S3004:
Speed: 0.23 sec/60 degrees at 4.8V
0.19 sec/60 degrees at 6.0V
Torque: 44 oz-in (3.2kg-cm) at 4.8V
57 oz-in (4.1kg-cm) at 6.0V
Length: 1.6" (41mm)
Width: 0.8" (20mm)
Height: 1.4" (36mm)
Weight: 1.3 ounce (37.2 grams)
Connector: "J" type with approx. 5" wire
And the S3151
Speed: 0.21 sec/60 degrees at 4.8V
Torque: 43.1 oz-in @ 4.8V
Dimensions: 1.59x0.79x1.42 in (40.6x20x36mm)
Weight: 1.48oz (42g)
So as I see it, as long as you use the servos in pairs (same servo for both ailerons or pull-pull), it should be fine.
Hope this helps.
Old 05-16-2005 | 09:22 AM
Put one of the S3004's on the throttle and the the other 2 where they are not mechanically interconnected.
Old 05-16-2005 | 10:08 AM
Thanks for the info so far. Bruce88123, that was my next question. Here's where I'm going to need servos:
Throttle
Right Flap
Left Flap
Airleron
Retracts
Elevator
Rudder/Tailwheel
I have four S3151 digitals, and I guess I'll purchase 3 S3004's. Where should I use the S3004's?
Also, I just want to make sure that I'll still have the same benefits of PCM, even though I'm mixing the s3004's with the s3151's.
Joe
Old 05-16-2005 | 10:51 AM
Pilot Chad's Avatar
4 flap servos? Can't you do 1 and then wire then together as one? I would use s3004 on flaps and rudder
Old 05-16-2005 | 11:44 AM
Chad, where does he say anything about 4 flap servos?
I am assuming that you are using 1 servo for each surface.
S3004 on throttle and rudder/tail wheel.
Will retracts work with a standard servo or will they need a special retract 180 degree servo or a high torque? If a standard servo will work, use a S3004 there.
BTW- There are other places to buy servos than Tower you know.
Old 05-16-2005 | 08:28 PM
bruce88123,
I didn't think about the retracts! This is my first time using retracts, and they might need a special servo. I'm using the Century Jet pneumatic retracts for my TF p-51 mustang. Does anyone know if I'll need a special servo, or can I go with a standard servo?
Joe
Old 05-16-2005 | 08:33 PM
Just wanted to add that they're pneumatic retracts, not mechanical. Would I still need a high torque servo or a specialized servo?
Old 05-17-2005 | 07:18 AM
If they are just controlling an air valve any std servo will be fine including an S3004.
