 Expanded scale voltmeter >
Old 06-12-2005 | 10:26 AM
Default Expanded scale voltmeter
I have a hanger 9 expanded scale voltmeter when i test abattery on it reads as if the battery is charged...however when i use another meter on it or a multimeter it reads less than what i had on the hanger 9. does the hanger 9 put the batery under a load, or is there something i need to adjust on it?
Old 06-12-2005 | 10:51 AM
Default RE: Expanded scale voltmeter
I just picked up a H9 ESV myself. It's odd that you would get a lower reading with a multimeter as the ESV *does* load the battery, which should make it's reading lower than the multimeter's reading.
Just to test the accuracy, I plugged my freshly charged receiver pack into the ESV and got a reading of 5.4V. While still plugged into the ESV, I put the probes of my Fluke meter across the ESV probes and got 5.4V as well. At least mine is accurate then.
Cary
Old 06-12-2005 | 06:02 PM
My Feedback: (85)
mighty odd for sure.
Old 06-12-2005 | 06:34 PM
Pilot Chad's Avatar
Seems that there was a post where the H9 was off a bit back. Search for Calibrate your voltemeter..
GREAT POST CARY!
Old 06-13-2005 | 06:54 AM
Either or both meters may be off and need to be calibrated. Check both from a known source, like a bench power supply with an integral meter of its own.
Dr.1
