splits
Old 09-01-2005 | 05:46 AM
Banned
Default splits
hi every 1,
i was puting bolts through my landing gear yesterday and i came across a split at the bottom of the plante and half of it was wet with petrol and hal wasent, anyway half of the plane bottom has cracked so im replacing it with strong ply aand using 15min epoxywhy is the trainer made so crappy and weak?
Old 09-01-2005 | 08:49 AM
Default RE: splits
Excuse my bluntness but what language are you trying to use? We normally use English on this forum as it is easier to read.
Old 09-01-2005 | 09:02 AM
Charlie P.'s Avatar
Default RE: splits
Trainers are made weak because they (like all aircraft) have to be made light. Most have "crumple zones" that are designed to fail in the stress points so you don't destroy the expensive components (radio, engine, servos). Trainers take a lot of punishment, and if the landing gear was rigid you'd rip it off the plane frequently. Even when this happens it's usually an overnight fix with white glue. Better to tear off the floor than snap the whole fuselage in two.
First order of business should be to find out where the fuel is coming from. There shouldn't be any in the plane (except in the tank), and the outside should be coated to prevent intrusion (covering, dope, paint, etc.) from the exhaust or spills. A cracked tank or hole in a fuel line will make the engine run poorly or cut-out, not to mention the mess. Soaking up fuel also adds even more weight to an airframe.
Old 09-01-2005 | 02:21 PM
Banned
Default RE: splits
sorry bruce.
Old 09-01-2005 | 02:28 PM
My Feedback: (16)
Default RE: splits
As long as he can convey his meaning and the post is on topic, we should attempt to assist him resolve his RC related issues.
ORIGINAL: bruce88123
Old 09-01-2005 | 02:39 PM
Default RE: splits
My appologies.
Old 09-02-2005 | 05:15 AM
Banned
Default RE: splits
the fuel is dripping out of the end of the exhaust and im burning it lean and im using 5% thats probibly why.
