 Prop Saver O-Ring/Rubber Bands >
Old 08-15-2006 | 06:08 PM
Default Prop Saver O-Ring/Rubber Bands
What size O-Ring would you recommend for a prop saver? My rubber band broke and I realized I don't have a replacement. Or, what kind of rubber bands?
Should these break often? I tried a couple of the rubberbands that came with my SS and those sheared off after about 5 seconds. Maybe I didn't have them tight enough.. *shrug*
-BlackNoir
Old 08-15-2006 | 09:35 PM
Default RE: Prop Saver O-Ring/Rubber Bands
U Should Be Able To Find A Supply Of O-rings At A Good Bearing Suppy House ,Auto Store Or Plumming Supply House.
Then It Is Hit And Miss.Take The Motor ,Adp.And Prop With u.
Old 08-15-2006 | 10:38 PM
Rookie here,
What is a prop saver?
Sarge
Old 08-15-2006 | 11:21 PM
Ken Erickson's Avatar
Check out the little rubber bands sold for women's ponytails. I got a bag at Wal*Mart in the Hair section. probably want to use more than 1.
Ken Erickson, AMA 19352
Yes, old.
Old 08-16-2006 | 07:13 AM
Sarge, it's a peice you put between the motor and prop which is supposed to help save the prop if you crash. It's helped me a few times but I'm still breaking some.. Guess it depends on how hard you hit..
Old 08-16-2006 | 11:44 AM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Well, I've been in this hobby for 10 years and I've never heard of anything like this. I've got a feeling that somebody is just playing around here on the threads having some fun. Unless somebody can show me that these actually exist I'm going to shut down this thread.
Ken
Old 08-16-2006 | 11:51 AM
No joke Ken. Here's an example: http://www2.towerhobbies.com/cgi-bin...?&I=LXJEW0&P=V
They're supposed to help by letting the prop bend away if you nose dive.
Old 08-16-2006 | 12:12 PM
RCKen's Avatar
My Feedback: (9)
blacknoir,
I do stand corrected then. I had never heard of them, but then again I don't fly electrics either. You might try asking this quetion over in the electrics forum too.
Ken
Old 08-16-2006 | 03:43 PM
The obvious solution is to keep the plane from crashing. I have used one of these on a foamie, but I just don't bother anymore. Just cut the throttle before the nose touches-down and your prop will last forever, even with no LG, like mine.
I fly Charger CR-1's (without landing gear) every single day and the only time I ding a prop is if I forget to cut throttle completely on landing....UM....or fall out of a low hover AND forget to cut throttle...OR.....just plain nose it in (in that case a 'prop saver' won't help anyway).
But really those 'prop-savers' are more trouble that they are worth IMHO. Just keep the prop from hitting ground and you'll be fine.
Have Fun!!
Old 08-16-2006 | 04:24 PM
Here are the recommended o-rings
http://www2.towerhobbies.com/cgi-bin...?&I=LXJPH2&P=M
A little pricey but i'm guessing they last a while if not lost. Take one to the local auto part store and buy replacements?
