 Monokote on Ultracote??? >
Old 09-12-2006 | 07:40 AM
Default Monokote on Ultracote???
Ok guys, rookie question here....
I am the happy owner of a H9 Twist 3D, covered with Ultracote.
I am going to decorate the Plane with some decalls. Am I able to use Monokote on the plane, or does it has to be Ultracote??
Thanks in advance for answering my questions guys...
Old 09-12-2006 | 07:47 AM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Monokote on Ultracote???
You can use either Ultracoat or Monokote for adding trim on top of your existing Ultracoat. One plus for the monokote is that you can use windex to apply the monokote over the ultracoat which improves the resulting finish, this method allows you to apply the monokote with no trapped air bubbles underneath. You can't use windex to apply ultracoat and it must be applied with heat. The reason for this is because the ammonia in the windex actually activates the adhesive of the monokote, but ultracoat uses a different type of adhesive and won't work. You can find a good article on how to apply graphics with monokote here: [link=http://www.rcuniverse.com/forum/m_603331/anchors_603331/mpage_1/key_flag/anchor/tm.htm#603331]Applying monokote graphics with windex.[/link]
Hope this helps
Ken
Old 09-12-2006 | 07:55 AM
Ken, I owe you a nice cup of coffee my friend.
Thanks for the super fast reply, and yes, it sure was helpfull!!
I am definitely going to try that flag pattern explained in the URL you send. super!!!!!!
Thanks again Ken...good advice!!
