monkote trim sheets
I have always used it over monokote. I cover then entire model in my base color then apply the trim on top of that. It goes on real easy if you wet the surface with 409, apply the trim piece and move to the exact location you want then squeege out the 409 and any bubbles. It will then stick perfect.
skeeter
skeeter
So far, nobody's mentioned a very important point. Monokote Trim Sheet is NOT fuel proof. It's only fuel resistant and will come off after time.
Dr.1
Dr.1
