 Hanging plane from ceiling >
Old 10-01-2006 | 05:14 PM
Default Hanging plane from ceiling
As i accumulate more plane i can keep them on the floor. My parent wont let me get more until the rest are put away. I have no wall space(really). A laser sailboat is hanging from the ceiling on one side. Does anyone have an idea for hanging 3 plus planes. could you make a pvc rack and attach it to a harken hoister?
Dan
Old 10-01-2006 | 05:33 PM
Cyclic Hardover's Avatar
Default RE: Hanging plane from ceiling
Well, I hang my fuselages from the ceiling and the wings go on the wall and look like a stack of shelves.
Old 10-02-2006 | 05:45 AM
I found some 50 pound plastic drywall anchors at Lowe's. They simply turn in with a screwdriver. Use a plant hanger in them to hang your fuselages by cords looped under them.
Dr.1
Old 10-02-2006 | 09:14 AM
I recently made rack for a phaeton 90 bipe for garage ceiling out of pvc pipe. I followed a design in MA rag. Drilled holes in 2x4 for pipe drops and used long scews to secure as well as to fasten into ceiling joist. Located it above the pickup cab. Used pipe insulation foam on the pipe sections to buffer. Easy project.
Old 10-02-2006 | 11:42 AM
MannyEdge's Avatar
My Feedback: (9)
Here is an idea from [link=http://www.jlproducts.net/ProductSkyHook.html]JL Products[/link]. They are a little bit expensive, but they are sure are nice and built great!
Manny
Old 10-02-2006 | 12:06 PM
Banned
I like to hang my planes up with the wings attached with a strong guage fishing line. I usually pad the line where it attaches around the fuse, and tie the other on the prop shaft.
I usually hang my biggist plane above my wifes head over the bed. I'm a mean husband... she thinks it's going to fall on her one day, but that hasn't happened yet. LOL
I fly my planes every week almost, I only string them up during the winter months. My Goldberg Eagle I hope to fly this winter with the ski's. I'm currently recovering the wings as I write this. My Cover was 16 years old with many patches, it had to go.
Peter Dowling aka Luftwaffe Oberst
AMA District II # 56404
Aero Modelers Club
Pulaski, NY
Old 10-02-2006 | 12:44 PM
Home Depot has these two way adjustable overhead hangers for under $9.00ea. They adjust from 12.75" to 21" and hold 25lbs per side.
http://www.lehighgroup.com/crawford_...oks.htm#H13010
Old 10-02-2006 | 03:31 PM
LT-40's Avatar
Danny,
I had a similar problem to yours so I started hanging my planes from the ceiling. It was like that for about 2 years before I finally got sick of it. I always felt like it might fall down,(luky it never did), it was a little difficult and anoying to get it down, and the planes got realy dusty. So to solve the problem I made a free standing multi wing/ airplane rack made from pvc. Mine holds 2 40 sized planes and 3 wings. If you wanted it to be able to hold more planes, then you could just make yours taller. (Just a suggestion)
heres a pic.
Old 10-03-2006 | 02:23 PM
looks like a cool plane rack but i cant put it next to any wall. Also i can keep any planes in the house. My parents are afraid of the fuel spilling. My only option is to hang them
Old 10-03-2006 | 04:12 PM
MikeG4936's Avatar
I got some clothes line, and ran two parallel strings from one side of the garage to the other. The planes sit upright ballanced on the two lines. It works great, and my parents don't get angry when the mufflers leak castor oil everywhere.
Old 10-03-2006 | 06:42 PM
My Feedback: (13)
here is my solution for plane rack, home depot or hardware store shelf standards the slotted ones, you screw to the wall, and shelf brackets with plumbing foam, the 3/4 works best, for padding, adjustable and on the wall out of the way one 4' shelf set up will hold 2 to 3 planes and wings depending how tight you pack em I have a couple one by the shop T.V. and one over my building table the thing I like best is they are adjustable for different plane sizes
ID:	534822   Click image for larger version
ID:	534823   Click image for larger version
Old 10-19-2006 | 01:49 PM
tcarp's Avatar
My Solution...Of corse they are all electric foam. I was wondering if I could do the same with my Hobbistar.
ID:	543950   Click image for larger version
ID:	543951   Click image for larger version
ID:	543952   Click image for larger version
ID:	543953   Click image for larger version
ID:	543954   Click image for larger version
Old 10-19-2006 | 02:09 PM
Wild Foamy's Avatar
ive got a jamara cessna 120 hanging from the ceiling, i loop some Fishing fire under the wings and hang it from a Hook in the ceiling (but its a light foam plane) and it looks like the plane is banking so it adds to the cool factor
