 PROGRAMMING PROBLEMS >
Old 10-04-2006 | 10:19 AM
Default PROGRAMMING PROBLEMS
I HAVE A MULTIPLEX PARK FLYER WITH THE FUTABA 4VF TRANSMITTERS USING MINI NANO SERVOS AND I CAN'T SEEM TO GET THE RIGHT PROGRAMMING TO CORDINATE AILERONS TO WORK TOGETHER ANY ADVISE OUT THERE?
Old 10-04-2006 | 11:47 AM
Default RE: PROGRAMMING PROBLEMS
As far as I can tell this simple transmitter has no programming capabilities. For most sport models you will not need to mix rudder to aileron to execute a turn.
Old 10-04-2006 | 11:54 AM
ORIGINAL: MAGTF
http://www.futaba-rc.com/manuals/4vf-manual.pdf
Just what kind of "coordinating"did you have in mind?
Which park flyer do you have? Multiplex makes several versions.
Old 10-04-2006 | 12:27 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
As Bruce said, I think that there is a "terminology" issue here. Are you saying that both ailerons do not move when you move the stick on the radio?? One aileron should move up and the other should move down. Is that your problem?
Ken
Old 10-04-2006 | 02:19 PM
when i pull to elevate i have to pull down and to the left to get both ailerons to raise and push forward and to the right to decline and it does'nt matter what servo i have plugged into the receiver it remains the same (futaba 114 receiver)
Old 10-04-2006 | 02:27 PM
What tail configuration does it have?
No actual ailerons but "tailerons"?
You have us working in the dark still.
Picture ? Link to picture? Something?
Old 10-04-2006 | 02:39 PM
is it something like this
http://www.multiplexusa.com/models/P...aceScooter.htm
Old 10-04-2006 | 02:48 PM
I have a multiplex micro jet park flyer RR EP ARF 26" sorry guys I' m new at this ! it only has a pair of ailerons.
Old 10-04-2006 | 03:02 PM
hogflyer's Avatar
Is this the plane you have? If so, it uses elevons and requires a transmitter with mixing capability to mix the elevator and aileron functions. The Futaba Skysport 4VF does not have these function.
Where you wanting to use Micro Jet RR to learn on? If so, it'll last all of about 5 seconds. Its a plane for experienced pilots, and you need to consider a basic trainer to learn on with proper instruction.
Hogflyer
Old 10-04-2006 | 03:12 PM
I've been taken for my money, I PURCHASED THIS PLANE AND A F-16 HORNET THAT I know I can't fly and now I need new controls also any suggestions ?
Old 10-04-2006 | 03:21 PM
I'm gonna have to disagree with Hogflyer here. The Tower add doesn't indicate any special radio or mixing needed and in fact only calls for a very basic radio.
http://www2.towerhobbies.com/cgi-bin...T=2&I=MPUA2270
It's also a very inexpensive plane overall but I can't tell how difficult it would be to fly. It is very unfortunate that Tower failed to include an instructions link on their page.
MAGTF - if you purchased this from Tower call their support line for help. Otherwise contact Multiplex at http://www.multiplexusa.com or 1-858-748-6948
I'm betting it's something simple.
Old 10-04-2006 | 03:31 PM
hogflyer's Avatar
Here's the manual for the Micro Jet RR
http://www.multiplexusa.com/Support/...s/microjet.pdf
From what I can see, it has elevons. On page 9 of the manual is the first mention of "elevon" in the servo hook up. It's a poor manual written in multiple languages. I think Tower just skimmed through the manul and got some basic info from there. There is bottom view on page 18, and graphics on pages 15 through 18. I don't see any other way to control the plane as it doesn't have separate elevators and ailerons.
Hogflyer
Old 10-04-2006 | 03:49 PM
Now I'm having to agree with Hogflyer and I'm hating that because that puts MAGTF in a bind.
MAGTF, where did you buy this?
Old 10-04-2006 | 04:35 PM
opjose's Avatar
This plane requires the elevon mixer, Tower has one for the Super Slinger that he can use.
There is nothing deceptive about this... merely a "user error".
See:
http://www2.towerhobbies.com/cgi-bin...&I=LXELT4&P=ML
It's cheap.
Old 10-04-2006 | 04:47 PM
That should do the trick. Shoddy manual though. [:'(]
MAGTF - Is there room to sneak this in?
Old 10-04-2006 | 04:50 PM
I purchased this plane at hobby house in North Royalton, Ohio. I called the manufacturer and yes it does need a mixer, I'm going to start all over. I'll keep this plane for future use. Thanks to all of you for your responses, two heads are better than one!
