 What O.S Engine to get ? >
Old 10-16-2006 | 06:37 PM
Avistar 2's Avatar
Default What O.S Engine to get ?
I got my Tower voyager ARF MK2 and I'm to decide which OS engine to get for it
Should I get the OS 40 or OS 46?
and what place online that has a radio set up for better bargan..
Old 10-16-2006 | 06:48 PM
Default RE: What O.S Engine to get ?
The best engine in that power range is the OS .46AX, but it's expensive. You can get an OS .46 LA for around $60. Get that one, unless you can afford the AX which will transition nicely into a second plane.
I have an OS .46 LA NIB and I will probably never use it as I am into larger planes now.
Old 10-16-2006 | 06:52 PM
Avistar 2's Avatar
I order the OS 46 LA than, I'm also in the market of getting a radio set up for it
Old 10-16-2006 | 07:04 PM
XTOL's Avatar
I am teaching one of our new club members to fly
and he has a Tower Voyager so Im getting to fly
it quite a bit. I am mildly surprised that its a quite
good flyer. Better than I expected.
He has an OS 46 AX on it and its way more engine
than necessary. The 46LA would probably be fine
on it but I would recommend getting something like
a Thunder Tiger 46 Pro.
The TT46 iis still going to be more motor than the Voyager
really needs but its lots less expensive than the AX and
unlike the 46 LA it will be more adaptable to planes you
are likely to get later.
The LAs are pretty dependable motors but are pretty
anemic powerwise.
Mike Hammer
Old 10-16-2006 | 07:08 PM
Avistar 2's Avatar
It is very handsome plane I can't wait to get my AMA card so I can start learning my self
I be lreaning on my Avistar mk 2 the Tower Voyager was my 2nd choice to get since everyone was out stock of the tiger 2
Old 10-16-2006 | 07:16 PM
Welcome to our addiction.
You will find that most people are more than willing to help new flyers. We all started there too.
Go get an instructor...I recommend having a few instructors to maximize stick-time, but some instructors prefer for a student to stick with one.
I had my own Buddy-box, (they are cheap), which helped me get lessons from un-suspecting flyers at my club. Be aggressive, but polite and grateful. you will learn in no-time.
Good luck!!
Old 10-16-2006 | 07:21 PM
Avistar 2's Avatar
Thankyou, Is $120 is good price for radio setup?
Old 10-16-2006 | 07:28 PM
depends on the radio
Old 10-16-2006 | 07:32 PM
Avistar 2's Avatar
Futba sport at tower hobbies .com
You may want to wait on the radio untill you see what is popular at your field. You instructor should be able to program your radio and it should be easily compatible with his in order to 'buddy-box'.
Why don't you call one of the club board members or send an e-mail directly. It may be a way to get more specific info.
Old 10-16-2006 | 07:34 PM
Avistar 2's Avatar
I did but no one has email me back ...
Old 10-16-2006 | 07:35 PM
Look in the RCU marketplace. I have a RTF trainer package to sell, but it includes plane, field equipment, radio, buddy-box etc. I want to keep it as a 'package deal'.
I'm sure you will have no trouble finding what you need.
My Feedback: (47)
Avistar 2, IMHO leave the LA series alone unless you just absolutely can't afford better. The Voyger deserves a better engine than an LA. You can always throttle back, thats what the left stick is for. A TT46 PRO or an OS46 AX or older FX would be a great match.
$120 for a radio?? What radio?? We need more info.
Fred
Old 10-16-2006 | 07:40 PM
Avistar 2's Avatar
on towerhobbies.com there one set for a $120
but I settle for a 4 channel used with servos and radio and reivcer,
I get paid next month I afford 83 bucks how good of condition it's in?
Old 10-16-2006 | 07:53 PM
Cambo's Avatar
Avistar, i know you just baught a 4 channel radio but if you ever have the oppertunity go with a 6-10 channel computer radio. Computer radios give you much more room to grow.
Old 10-16-2006 | 07:55 PM
Avistar 2's Avatar
I can't afford a PC radio setup...[]
I'm not that rich..
Old 10-16-2006 | 08:13 PM
XTOL's Avatar
Avistar...I know you're eager to get started but take a bit of advice
from someone that does a lot of training...wait until you line up
an instructor before you buy too much stuff. Especially a radio.
The equipment you get should be familiar to your instructor.
It will save you BOTH invaluable time. If your instructor
is a JR guy then you would be better off going that direction.
Its easier to buddy box JR/JR and Futaba/Futaba.
Your instructor will be the single most important thing
to line up. Far more important than a radio or engine.
There is a lot more to learning to fly than merely
learning not to crash.
Mike Hammer
Old 10-16-2006 | 08:18 PM
Avistar 2's Avatar
Ok, Beside I have to ask him if he help to the radio gear in the tower Voyager mk 2
this plane is very nice looking, they were out of stock of the tiger 2s
Old 10-17-2006 | 03:45 PM
opjose's Avatar
Yeah contact a field instructor before you do anything else.
Forget the LA engines they have far less power than the FX/AX series and feature only a single needle valve and a bleed valve for the low end.
The low end is almost impossible to set correctly on the LA series.
I have a 40LA that runs too rich on the low end and there is no way to lean it out as the screw is fully open on the bleed valve.
Ugh... not worth the time and effort.
Old 10-17-2006 | 04:25 PM
ORIGINAL: opjose
OPJOSE - drill the hole open a tad bigger. One drill size at a time.
Old 10-17-2006 | 04:52 PM
opjose's Avatar
I tried this.
It helped, as at least the engine runs stabily now w/o flooding out, but it is still too rich and the hole is big enough that I don't want to go any further.
Thanks.
