Fuel proofing Field box
Originally posted by rajul
Hi whirleybird,
The pump is a slimline boxxer. about the best and most reliable electric pump out there. Tower has it. The carry bar is not removable but the cradle is. I used a good old razor saw and B&D rtx (dremel equivalent, only more power
). the curves are done by marking out with pencil (I copied the outline of my ernst ultra stand), then drilling holes along the marking and "joining" up the holes with a Higley reamer bit, and final sanding with a sanding drum. let me know if you need anything else..................mike
Hi whirleybird,
Check it out
