 Choices, choices.... >
Old 02-11-2007 | 07:27 PM
dt50chev's Avatar
Default Choices, choices....
I'm a newbie and of course I have questions. I have a Goldberg Eagle2 .40 size and I have a Lanier Indicator .049 size with throttle. Which would be the better plane to learn to fly on?
Old 02-11-2007 | 07:33 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Choices, choices....
Go with the Eagle II. Bigger is always better. The bigger trainer is going to fly smoother than the little one.
Ken
Old 02-11-2007 | 07:35 PM
ChuckW's Avatar
ORIGINAL: RCKen
Ken
I agree, 1/2A stuff is neat but a nice .40 or .60 trainer is probably more appropriate as a starter plane.
Old 02-11-2007 | 07:40 PM
My Feedback: (27)
This is painless. The Eagle is the logical choice hands down. The size lends it's self to being seen and being able to make slow easy flights, desired by all students at least at first.
Small planes require you keep them fairly close to see them and control them. Were I teaching you I would insist on the Eagle given the choices. Also small planes , small servos, etc., none any less expensive than standard servos, savings would be minimal.
I don't even know what an Indicator is but if it calls for an .049 it's to small for a good trainer, period.
Use a good BB 46 on the Eagle.
Old 02-11-2007 | 07:54 PM
No doubt about it - the Eagle is the only choice for learning with between the 2.
Also be sure to get proper instructional help. PLEASE don't try to do this on your own.
Old 02-11-2007 | 08:04 PM
tailskid's Avatar
My Feedback: (34)
Which plane does your instructor prefer?
Old 02-11-2007 | 08:23 PM
Fastsky's Avatar
For sure the Eagle2!! Then add either an OS 46AX or thunder Tiger Pro 46 engine with an Master Airscrew 11-5 prop and you have a great start. [8D]
Old 02-12-2007 | 08:48 AM
dt50chev's Avatar
This is an older model. It's fully assembled but needs a few repairs. It has a Super Tigre .40 and a Futaba Conquest radio. I need to replace all the batteries. What's a good source for batteries?
Old 02-12-2007 | 09:26 AM
www.towerhobbies.com or your LHS. Take your old batteries with you.
Old 02-12-2007 | 11:02 AM
My Feedback: (27)
Sounds like you are well on your way !!!!!!! This set up will work just fine as long as the engine is in decent shape.
GOOD LUCK!!!!!
Old 02-12-2007 | 11:59 AM
Save the Indicator for after you learn to fly the Eagle, then you will understand why they all suggested the Eagle first. Adrenaline, Adrenaline, adrenaline. ENJOY !!! RED
Old 02-12-2007 | 01:36 PM
dt50chev's Avatar
I've run the engine on a test stand. It seems to run well. Just need to make some adjustments on the carb, the moving prop scares me a little.
Old 02-12-2007 | 01:59 PM
ORIGINAL: dt50chev
GOOD, keep that attitude and keep your fingers. That thing is a meat slicer and deserves ALL the respect you can muster.
Old 02-12-2007 | 02:07 PM
MinnFlyer's Avatar
ORIGINAL: bruce88123
ORIGINAL: dt50chev
So true. Sticking your fingers in that meat slicer accounts for 90% of the stiches received by us airplane nuts.
Wives account for the other 10%
Old 02-12-2007 | 03:18 PM
DT,
I run my Eagle II with an OS 40 LA and it flies very well.
There is no need to change your engine as long as the one you have runs well and is reliable.
Good Luck,
KW_Counter
