 metal to metal interference >
Old 03-09-2007 | 07:04 AM
Default metal to metal interference
Can a tailwheel with a metal hub on the axle cause interference? Or any metal washers on an axle?
What other metal to metal on a plane will cause it?
Old 03-09-2007 | 07:13 AM
Default RE: metal to metal
G'day Mate,
Yes, metal tail wheels can be a problem, but the washers should not be a problem, they usually can't move enough, or have enough contact area to cause a problem.
Usually the tail wheel is close by the end of your RX aerial.
But be aware, that running the aerial past your switch & servos, or parrallel with servo wiring, can cause more problems than a metal tail wheel.
Old 03-09-2007 | 07:40 AM
Wonder why they make metal hubs on a tail wheel? Do they think you will be using a plastic axle or something?
Old 03-09-2007 | 08:20 AM
ORIGINAL: alan0899
You mean directly next to servo wiring, right?
Old 03-09-2007 | 08:36 AM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: metal to metal interference
Actually, the hub on my tailwheels are made of aluminum. That does not cause the RF signals when it contacts other metals. RF interference are cause by ferrous (containing iron) metals rubbing against each other.
Ken
Old 03-09-2007 | 08:39 AM
Maybe mine are aluminum. Thanks
I know they are aluminum now...thanks again.
Old 03-09-2007 | 08:43 AM
Can the metel clevis on a metal pushrod cause interference if they aren't soldered on?
Old 03-09-2007 | 08:47 AM
RCKen's Avatar
My Feedback: (9)
ORIGINAL: kc31406
I assume you mean the threaded clevises here. Yes, they can cause interference if they aren't tight. That is what the jamb nut is for behind these types of clevises. They nut is tightened down against the clevis so that it can't vibrate in flight.
Hope this helps
Ken
Old 03-09-2007 | 08:53 AM
That is what I was pertaining to. The threaded clevis. Thanks
I wonder if thread lock would also cure it?
