RX/TX Question
Hi:
I'm a super-noob when it comes to radio systems. My question, I own a Hitec Optic 6. Specifically this one, http://www.greathobbies.com/producti...d_id=HIT158721
I was contemplating a long term project and was thinking of this Flight Pack, http://www.greathobbies.com/producti...od_id=JSP40030
Since the rx & tx are of differing brands, will the jrsport receiver work with my transmitter?
Tom
Tom
The Hitec transmitter you have sends out a Negative shift signal and JR requires a Positive shift. Futaba uses Negative shift signals so you can use their receivers but you will likely find the Hitec stuff cheaper and just as good... Oh and Tower Hobbies brand receivers are just Futaba with different stickers on the face.
EDIT// Oh just read the fine print on your radio. It is Shift Selectable so yes that JR flight pack should work.
My Feedback: (12)
ORIGINAL: Rodney
Shift should be no problem, you can program the Optic 6 for either, use positive shift for the JR and Airtronics receivers, negative for Hitec or Futaba.
