 evolution 45/46 >
evolution 45/46
evolution 45/46
Old 08-10-2007 | 08:57 PM
dragnbye's Avatar
Default evolution 45/46
ok i put this here becuse i still learing but here it goes. i have a power systems a 40 the one that comes with the alpha 40. what i the difference the 40 is really a 45 this the info on the two
this is the 46
Product Specifications
Type:2 stroke glow
Displacement:.47 cu in (7.65 cc)
Bore:.86 in
Stroke:.80 in
Cylinders:single
total Weight:16.96 oz
Engine (Only) Weight:13.76 oz
Muffler Weight:3.20 oz
Crankshaft Threads:1/4 x 28
Benchmark Prop:11x6 @ 12,500 rpm
RPM Range:2000-12,500
Fuel:10% - 30% Nitro
Mounting Dimensions:44mm x 17.5 mm
Muffler Type:Cast
Cylinder Type:ABC
Carb Type:Barrel, with two needles
Crank Type:Ball Bearing
this is the power systems a
Type:2-stroke
Displacement:.45 cu in
Bore:.87 in
Stroke:.77 in
Cylinders:Single
Total Weight:19.52 oz
Engine (Only) Weight:16.32 oz
Benchmark Prop:10x4
RPM Range:2,000-16,000 rpm
Mounting Dimensions:44mm x 17.5mm
Muffler Type:Cast
Cylinder Type:ABC
the bore is bigger rpm is higher the the trainer sys
Old 08-10-2007 | 10:18 PM
Missileman's Avatar
Default RE: evolution 45/46
not much at all.
They are hitting insane RPMs on the 2nd engine because they are underloading it with that 10x4 prop, not enough prop for that size engine IMO.
(I used that word "Insane" in 2 threads today )
It doesn't say if the 45 is a ball bearing engine, that would make a difference.
Old 08-10-2007 | 10:23 PM
Insanemoondoggie's Avatar
I have a .45 evo , it turns a APC 11x6 13000 +. Both the .45 & 46 are bb engines.
Old 08-11-2007 | 06:18 AM
dragnbye's Avatar
it dosnt say that it is ball bearing but if you look at the exploded parts veiw you can see it and it's call "bb".
i just cant see a company makeing two differnt molds for .01 ci
Old 08-11-2007 | 06:20 AM
dragnbye's Avatar
also are there any kind of muffers that fit thesse engines
Old 08-11-2007 | 06:32 AM
I found this for Pitts mufflers [link=http://www.wholesaletrains.com/Detail.asp?ID=200412268]pitts[/link]
Old 08-11-2007 | 12:12 PM
Alpha 40 is referring to the "plane caategory" and NOT the engines actual size. Evolution has NEVER claimed to make a .40 engine.
Also note that these are Evolution engines. Do not confuse them with Evo engines which are a different brand completely.
Also note the .45 and .46 have different strokes which means different crankshafts and most likely many other different components.
Old 08-11-2007 | 02:16 PM
The Evolution TPS engine is a good engine. It comes with a 10.5x4 three blade prop, three blade spinner, and a flywheel drive washer. If purchased separate from the plane it will also have a standard drive washer. Most people switch to a two blade prop and spinner when they brake the included three blade model. I broke mine on my first landing on my own. A APC 10x7, two inch spinner and standard drive washer worked well for me. The 10 inch prop gave me a little more ground clearance over an 11 inch prop.
The Evolution .45 has an A on the head, the .40NT has 40 on the head and the .46 has 46 on the head.
Old 08-12-2007 | 12:34 PM
dragnbye's Avatar
i been running a 11x4 on it form day one and it got good power to pull it anywere i point it. but i just put this on my pluse and a bought some diff props to try out. so i will see what likes i had gallon and a 1/4 thought it so far
