 Prop installation question! >
Old 08-17-2007 | 10:27 AM
CGRetired's Avatar
Default RE: Prop installation question!
I use the electric starter for the first time starting the engine on a flying day, only on my OS 1.20 AX engines. I am somewhat afraid of that prop.. even if I use a chicken stick.. I just use the electric starter once, start it to get it warmed up, then after that, I tap (whack) (is that a real word?) the prop backwards against the compression and it starts right up in the forward direction.
Old 08-17-2007 | 02:37 PM
Missileman's Avatar
Another way of using an electric starter wrong.
Get the starter spinning in the air and then jam it onto the spinner.
A guy at my club does this and I cringe every time [:@]
Old 08-18-2007 | 05:19 PM
747's Avatar
747
I installed the prop the way da-rock said...Da rock rocks! This is the only way it will come thru the 2 holes in spinner and thus doesnt touch the stubs at all...
Any ways I have a 10x6 [or 7?] Prop for that.Since its a OS46FX, some one at the field suggested a better one (11x6) plastic master airscrew prop since the current one makes engine too loud. He said a 11x6 would be smooth and good for the engine life and rpm....
What do you guys suggest? 11x6?
Old 08-18-2007 | 11:04 PM
somegeek's Avatar
ORIGINAL: Minnreefer
Thanks Ken, I am doing it "right", I noticed that sometimes when I hand start my engine it runs backwards, what am I doing wrong, or does it jsut do that?
Jon
Sometimes engines do this when you hand start them... from idle, give the engine a blip of throttle. Sometimes they will bounce against the compression and right themselves.
somegeek
Old 08-19-2007 | 04:24 AM
If it starts backwards when you're handstarting, it's because that last flip wasn't hard enough.
