 Replacement Engine Help >
Old 09-11-2007 | 08:57 AM
chopper man's Avatar
Default Replacement Engine Help
I'm putting together an order to replace my lost trainer. Because of my funds being low I was going to get the OS .46LA. It is out of stock so my next option would be the GMS .46. 2 bucks more. In your opinion what is the better engine? I'm putting it on another Tower trainer.
Thanks for your help.
Chopper man
P.S. This order does include the airplane finder
Old 09-11-2007 | 09:19 AM
Insanemoondoggie's Avatar
Default RE: Replacement Engine Help
Chopperman . I just bought a GMS .47 with front needle valve . Just finished running a 1/2 gallon of fuel thru it. On the stand , it runs very well after it`s broke in. It was one of the harder starting, tweaking engines ,I ve broke in . After break in , idle , transition and top end are great.
It should pull a trainer well. It is louder than my other .40 sized motors.
I also have 2 ST GS 40 that pull my LT-40 and a Tower trainer well. I liked them on trainers so much I bought 2 of them to train others with. $49,99 not a bad price.
Old 09-11-2007 | 09:22 AM
Cyclic Hardover's Avatar
I would get a St45 or TT 46pro before either of thge other two.
Old 09-11-2007 | 09:25 AM
chopper man , i have just been reading a report on the GMS engines , done by our engine guru here in Australia , and by all accounts itis a very well made engine , develops heaps of power , and is very stable , with little vibration, so i would say yes , the GMS would be a good buy,
Bill
Old 09-11-2007 | 09:49 AM
mclina's Avatar
Have you considered the Magnum XLS-46? It is a ball bearing engine for almost the same price as the LA-46. It weighs about 4 ounces more. I have heard good reviews of it and am considering it for my next build.
Edit - I just realized that the GMS and Super Tigre engines that have been recommended are also BB engines. I'm going to have to check those out as well.
Good luck
Old 09-11-2007 | 10:15 AM
I have I just don't know enough about the engine.
Chopper man
Old 09-11-2007 | 10:25 AM
-pkh-'s Avatar
For a .40 size plane, I'd get a BB engine over the .46 LA, or get at least get a .65 LA for it. From what I've heard, the Tower Hobbies or the Magnum .46 engines would work well.
Old 09-11-2007 | 10:28 AM
OzMo's Avatar
check out EBAY often they show some good deals. HOWEVER I would only consider NIB or new in the box listings, Older models such as O. S. FSR and FS series engines are common that are fine motors. do your research and DON'T overbid.
Also look at the KANKGE SK 50 it is an ABC ball bearing and is $60.00. I have the 90 and its super (slow to break in and slow to wear out)
Old 09-11-2007 | 10:39 AM
My Feedback: (13)
What about a Super Tiger 45? Great engine.
Old 09-11-2007 | 10:41 AM
Super Tiger engines don't have the rear needle adjustment. (Do they??)
chopper man
Old 09-11-2007 | 10:47 AM
mclina's Avatar
ORIGINAL: ro347
Hey ro347,
I see in your models that you have two planes with OS .46 AX's and one with the Super Tigre GS-45. What are the differences? Is the OS worth $50 more than the ST? It would be great to get advice from someone who is running both engines.
Old 09-11-2007 | 11:04 AM
opjose's Avatar
ORIGINAL: chopper man
Chopper man
There is nothing wrong with the GMS .46.
It's a GREAT engine. It is FAR more powerful than the OS .46LA by a large factor.
GMS manufactures Tower Hobbies engines too.
Get it, clamp down the carb with a soft vise grip and then tighten the carb hold down screw. This is a must to avoid airleaks, that are the primary cause of problem reports with this engine.
Don't change the settings as it comes out of the box.
It will start up just fine the way it is.
Run a couple of tanks through it at whatever speed it will hold ( usually not full throttle at optimal RPM's out of the box... ).
Then carefully adjust the needles. Usually 1/4 turn movement is more than enough to get it right. The needles are a bit sensitive.
Run a couple of more tanks through it, alternating the engine speeds up and down.
Once down re-tighten all of the cap screws (including the engine head screws!), and carefully retighten the muffler. All of these will work loose after the first runs.
Then go fly...
You'll find it to be a fairly powerful engine, much more so than the SuperTigre, and stronger than the TT's.
BTW: The O.S. are much easier to set up out of the box and are practically ready to run.
However the GMS/TH with the above caveats are great bargains.
Old 09-11-2007 | 11:29 AM
chopper man
No they do not come with a remote needle .
The easist engine , I have used yet, is the OS .46AX. A little spendy, but a no brainer.
Old 09-11-2007 | 12:16 PM
ORIGINAL: Insanemoondoggie
chopper man
That was my first choice but I can't swing the cost. Looking for the next best thing.
Chopper man
Old 09-11-2007 | 12:40 PM
The GMS is a good choice, it does have a slightly larger muffler , but I think thats one of the reasons it runs so well. I got mine with a coupon for 44.95 from Tower. Had to try one out . A freind has one on a trainer and it screams.
Old 09-11-2007 | 12:45 PM
opjose's Avatar
Wow, was this with one of the e-mailed coupon codes?
If so, please post! I'd love to pick up a couple at that price!
Old 09-11-2007 | 01:01 PM
Please provide the code #. That would be a great great help to me.
chopper man
Old 09-11-2007 | 01:22 PM
My Feedback: (13)
As ive said before in other posts.....the OS looks nice....but the Super Tiger is an amazing engine.....lots of power....great price. I almost want to say the super tiger feels as if it has more power than the OS> Might not be the case as per the Specs(not sure)....but just going by how one of the planes flew after having both the OS and ST in it. I was skeptical at first being that my first engine was the OS. But I am VERY happy with the ST and am glad I saved myself the $50 bucks. Only thing...I ran 3-4 tanks fo fuel when first started the ST to break in on the ground a little. Oh...and be carefull with the muffler....gets hot as F&^%! Figured that one out on my own-
What will you be putting it in?
Old 09-11-2007 | 02:06 PM
mclina's Avatar
ORIGINAL: ro347
I picked up an old (~1981) NIB kit for a Northeast Bel Air 40 biplane at a club swap for $50. I was originally budgetting as a winter project to build a GP Ultimate 40 with an OS 46AX. I have already saved about $60 on the kit part of my budget. If I save another $50 on the engine part of my budget, I'll be well on my way towards glow plane #4. (If my wife buys into this excellent line of reasoning)
The Super Tigre is currently out of stock at Tower, but I'm going to my LHS this afternoon to see if they have one.
Old 09-11-2007 | 02:11 PM
OzMo's Avatar
Do a serarch on here RCU for tower codes theres a thread somewhere.
Old 09-11-2007 | 02:17 PM
mclina's Avatar
ORIGINAL: OzMo
The coupon code that Moondoggie is probably talking about is the much coveted "$20 off a $50 order" code, which Tower occasionally sends to you if you've been away from them a while. They are restricted to the recipient, and they expire quickly, but they are awesome while they last.
The only deal they are advertising right now is $25 off $199, which isn't enough to lure me away from the local hobby shop who is very competitive with Tower's prices, has a huge inventory, and great service.
Old 09-11-2007 | 05:48 PM
Gary L.'s Avatar
ORIGINAL: ro347
I have two, one came in my LT40, the other I bought new, I ran two tanks through it
and put it in the air with NO prob.
Just my .02
Old 09-11-2007 | 06:59 PM
Ugo Ferrari 's Avatar
Another vote for the GMS .47 ! I have 6 GMS's in different sizes, Three .47,one .40. 0ne .32, and one .25 all great ! A little longer to break in,( the .47) but a real horse when it comes in ! I break mine in the air.
Ugo
Old 09-11-2007 | 10:05 PM
My Feedback: (13)
ORIGINAL: mclina
ORIGINAL: OzMo
I used this one off of the Tower promo code thread and it worked. It wasnt emailed to me. I just used it last week.
011CK
Hope it still works
Old 09-11-2007 | 10:08 PM
My Feedback: (13)
PSSSSSSST! I just tested to see if it would still work.....YES IT DOES....so as Kramer says....BUY BUY BUY!
011CK
