 clear back plate >
clear back plate
clear back plate
Old 10-29-2007 | 06:04 PM
seemefly_1's Avatar
Default clear back plate
anyone seen one of these if so were can i get one
Old 10-29-2007 | 06:30 PM
RedGN's Avatar
Default RE: clear back plate
Any pictures????
Old 10-29-2007 | 07:35 PM
Are we to assume this is for an engine? If so, what kind? And for what purpose? Do you want to be able to run the engine with this in place or just use it for a paperweight/display?
I don't know of any that are produced but depending on intended use you may be able to make one.
Old 10-29-2007 | 07:50 PM
seemefly_1's Avatar
any engine. i think it would be neat to see it on an engine and while it is runing
Old 10-29-2007 | 08:00 PM
An engine that is running at 10.000 to 16.000 rpm , what do you expect to see at that speed? Just a blur. And when mounted 1/4 inch from a firewall, who is going to see in there? On a running engine i dont think it would be practicable. If my memory serves me right i think minflyer did a mobile view of an engine and posted it in here some time back . Maybe RcKen will remember it and dig it up for you .
Bill
Old 10-29-2007 | 08:04 PM
You might be able to make one out of clear Lexan but I don't expect it would last very long. Stay away from ANY type of glass as it could be very dangerous when it shatters.
Old 10-29-2007 | 09:46 PM
MinnFlyer's Avatar
ORIGINAL: the_madgenius
I totally agree, it just doesn't make any sense.
And BTW, here's that graphic I made of a running 4-stroke
Old 10-29-2007 | 10:01 PM
seemefly_1's Avatar
ok but seeing what it looks like after maybe breaking in were it was exposed would be neat or if there was a camera that could capture that it would be awsome but instead of telling me about how i couldn't see it tell me if there is one
Old 10-30-2007 | 06:50 AM
This might be feasable on a four stroke but highly doubtful on a two stroke engine. I have run a four stroke with a big hole in the backplate with no apparent problems just to see if it would run okay. It did.
Old 10-30-2007 | 06:58 AM
seemefly_1's Avatar
would that be if it had the carb behind the engine
Old 10-30-2007 | 08:52 AM
Charlie P.'s Avatar
You have to have good eyes to watch something spinning at 13,000 rpm and pick out much detail. ;-)
The insides look a lot like the propeller does, but will be covered in splashing oil and fuel.
Old 10-30-2007 | 09:35 AM
Gene Hempel told me about making an engine out of clear plastic and running it (with an electric motor, I suppose) with smoke going through it, in front of a high speed camera. Gene wrote the CL speed column for Model Aviation for 14 years, but I don't recall ever reading about this experiment. Anyone know anything about it?
Old 10-31-2007 | 12:27 AM
Sweet Graphic!!!
