 help!!!! >
help!!!!
help!!!!
Old 01-04-2008 | 12:24 AM
The_Lost_Otter's Avatar
Default help!!!!
is there any way to un-do 5 min expoxy?
i glue a peice on the wrong side[:'(]. i feel stupid
Old 01-04-2008 | 12:39 AM
Default RE: help!!!!
any one?
BadSplice's Avatar
Use a heat gun to get it really hot, it should soften up and come apart. I would do it outside though or somewhere with good venting... I never had the impression that epoxy gives off much in the way of fumes, but I heated some as I was putting it on the other day and my smoke alarm went off after 30 seconds.....
Old 01-04-2008 | 12:40 AM
if it dont work, do you think i can contact great planes and the ship me two new parts?
Old 01-04-2008 | 12:41 AM
BadSplice's Avatar
Most likely... but is it possible to just fabricate new parts?
Old 01-04-2008 | 12:42 AM
kuppler's Avatar
if you use a heat gun on epoxy it should start to crack. and you can pick away at it. and it will fall apart. you have to get it HOT... and i would do it out side and it does give off some nasty smells.... hope it works well for you..
Old 01-04-2008 | 12:44 AM
thanks i just tried it a little in my room, and it did soften it. now i just got to go out side wit out waking my mom
Old 01-04-2008 | 12:56 AM
i almost got it just need to get it hotter,
Old 01-04-2008 | 12:59 AM
kuppler's Avatar
thats good news... just get it HOT.... and u will be OK....
Old 01-04-2008 | 11:55 PM
i got it thanks guys
