Voltwatch, you all use 'em?
#128
SC
I decided to buy me 1 voltwatch......I'll just put it in one plane and have that plane pull all my others.
Cheaper that way rather than buying one for each plane.![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
#130
MO
How many planes will YOUR Voltwatch pull? I used mine the other day for a doorbell. Then used it after getting doorbell replaced to wash my car. Later that same day and some may not believe this but my grandson rode it to the stoor for a pack of gum. Man they have just so many uses. Let a voltmeter do all that!!!!.
#133
lost my cap232 to low rx. i was stupid. it was the only plane that i didn't have a voltwatch on and it went in as i dove for a low pass. dumb and dangerous. if you don't use a voltwatch, make sure you check the voltage EVERYTIME.
be safe.
be safe.
#134
MO
Oh man Forestroke that is terrible. We are just poking fun and then to hear that makes me cringe. Hopefully it is repairable. The Voltwatch may not be the best thing for cheking battery power but it does let you know something. I keep my batteries pretty charged up all the time. There have been occasions when i did not charge for a couple weeks and flew fine, but having a Voltwatch just gives you some peace of mind before you take your plane up. I don't own a voltmeter but alot of guys swear by them. Either way it is cheap 10- 11 dollars and looks good too. I don't know price of voltmeter as I probabaly will be stubbern and not buy one but expect they are fairly cheap also lots cheaper than a new airframe. Hate it for you my man.
CG what is that with the DOOR STOP remark? That was DOORBELL DOORBELL,
#135
![](/forum/images/badges/trading_plus_member.png)
Well, if it's a small enough door...
One more thing here. The voltwatch is not a loaded device. It relies on the existing load.. RX, servos as the load. So, it cannot be used unless the system is energized.. that is, that the receiver is powered on and supplying power to the servos. Other than that, it is not something that you can just plug into a battery and expect to get a correct reading. It will be high, and not loaded.
For an out-of-circuit test, an ESV must be used, or at least a voltmeter that takes a reading across a load of some sort.
#136
NV
I got a voltwatch for a gift recently and I have JR equipment. The voltwatch has a tab on the side of the plug that prevents me from plugging it into my reciever. Can I cut that off or should I just send it back?
#138
OH
ORIGINAL: TheBrickLayer
#139
I have a JR 4.8v 1100mah Nicad pack, 4.8v 2500mah Nimh pack and a 4.8v 2000mah. I have only used the JR RX pack of 1100mah and have been able to get a full days flying (5 or so flights) no problems. I think if I had a 600mah pack I would be getting worried. So my answer is to get a big capacity RX battery pack and you can insure if you charge the batteries with a peak detection charger the night before you will have no problems.
#140
OH
ORIGINAL: panzerd18
#141
True but if the battery is going to fail due to vibration then thats the risk I will take. It will probably fail when you are flying and there is nothing you can do once its in the air. On a 4.8 volt system, if one cell fails will it cause a total loss of controls as the voltage to the RX will be too low?
#142
OH
It depends on how it fails. A shorted cell will still deliver the voltage of the other cells and maybe even a little from it. You may still have control but you will lose some range. If the cell opens or a weld breaks you will have no voltage at all and no control.
#143
PA
I recently put in a voltwatch and I think the're great! I bought 2 more for other planes. And as someone else already said, you can move your stciks around and see the load that's being drawn so you have a good idea as to when your battery is getting weak.
#144
BrickLayer, the polarity is the same for the JR so just cut the tab off as suggested. Follow the link to see the wiring diagrams of the common radion systems. http://www.fatlion.com/sailplanes/servos.html
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
#146
ORIGINAL: testfly
Guys I have a few of the original VoltWatch units and want to be sure I can use them with nimh batteries. (5 cell AA)
#148
PA
The "Voltwatch" is for 4-cell (4.8V) NiMH and NiCd packs only. The "Voltwatch2" has a tiny switch on the side to select between 4-cell (4.8V) and 5-cell (6V) packs. There is also a "Voltwatch 12V Field Power" unit that is for monitoring 12V field batteries for your starter/charger. They are all labeled clearly and look quite different (see photos below):
#149
My Feedback: (17)
TX
Thanks for posting this. I've always wondered about the ones without the selector switch on them. I traded for one a few months ago, but haven't used it simply because I didn't know about it with no switch.
#150
IN
Whai value [ohms] resistor do I need to use a six-volt battery on a volt watch 1 ? All my birds have voltwatch ones inside the canopy.
