 Set Up Help >
Set Up Help
Set Up Help
Old 05-06-2008 | 09:24 AM
Default Set Up Help
Hi Guys,
I am new to the sport, thus the beginner post...
I started on a 4 CH motorized glider (400 brushed) last year. I think I have the hang of it and really enjoy it.
Last month I bought the VMAR Bird Dog ARF and i need some help setting it up.
It is 43 inches span, 29OZ. The recc motor is a 100-180 Watt Outrunner. I picked up a 178 Watt / 3800 RPM motor.
questions:
1. Only some engines that are forsale provide power in watts. How do I find a similar power engine with different ratings? Should I get less RPMs for this plane?
2. How do I select a good prop for this bird? I am thinking more power and time aloft than speed.
3. Radio question: when buying a radio does the receiver and TX have to be the same MHZ, then jsut swap crystals to change freq?
Old 05-06-2008 | 09:44 AM
Default RE: Set Up Help
There is an electric motors forum where you would probably get better responses....
Old 05-06-2008 | 10:05 AM
spiral_72's Avatar
ORIGINAL: wickman11
......Last month I bought the VMAR Bird Dog ARF and i need some help setting it up.
questions:
Welcome to electric stuff, where motor selection is an in-exact science at best. Companies don't really have a standard unit of measuring electric motors unfortunately. With a little experience you can find a good match though. I'll do my best:
I'd recommend about a 950kV outrunner. That should be rated at 16-18A. For a speed control, you can't go wrong oversizing the ESC. I'd go 25A. It'll handle the heat/current draw better and give you a little more buffer if you run the plane hard. Cost difference is minimal.
For prop selection, that'll be listed on the specs of the motor. You'll want a larger diameter, low pitch prop to fly slow with lots of torque. The larger diameter moves more air over the wings at a slower speed...... You're creating your own lift. With that 950kV motor, expect a 12x4 prop maybe? I think GWS makes a 12x3.75 or a 12x4.7
A 1200-1600mA 3-cell LiPo should give you 10-15min flight depending.... It's best to get a battery with a balance plug on it.... I'd also highly recommend getting an ESC with a balance port on it. That way the ESC knows what the individual cell voltages are instead of the average V of the whole pack and risk bringing one cell too low and damaging the pack like I did yesterday....
The transmitter and receiver should be 72Mhz for aircraft use. The "channel" is actually a deviation from 72Mhz...... 72Mhz is the base frequency, the channel is 72.xxxxMhz. You have about 50 channels. You buy a rx crystal to match whatever channel the transmitter is, never the other way around. Lastly, there are several different types of crystals, so a channel 45 crystal that works in a HiTec may not work in a Futaba....etc. Buy the channel crystal for the brand rx you pick.
Old 05-06-2008 | 10:08 AM
wings's Avatar
You can only change the crystal (legally) in the receiver, unless your transmitter has a module.
When you swap crystals you have to make sure the shift is the same, whether it's dual conversion, and if you have a Futaba radio, make sure the receiver is tuned for the frequency you want to change to. Either high band or low band.
This is all explained in more detail [link=http://www.hooked-on-rc-airplanes.com/rc-frequencies.html#3]here[/link].
ps.
Hey Spiral, that's the coolest Avatar I've ever seen!
Old 05-06-2008 | 10:12 AM
Thanks so much. So the motor I have at 3200RPM is too much? Everything else sounds super.
I understand the channel changing response as well. I think I mis-spoke.
Old 05-06-2008 | 10:16 AM
spiral_72's Avatar
HA! thanks! Unfortunately, the avatar was based on actual events. [] NOOOOOoooooooooooo!
Old 05-06-2008 | 10:22 AM
spiral_72's Avatar
I don't think you mean 3200rpm.... I might be wrong, but check it. I think you mean 3200kV! Which would be used on a 150mph delta wing or something. That's high power, really stinking fast.
Old 05-06-2008 | 10:31 AM
Right Spiral.
Here are the specs:
3200rpm/v 178W D2830 RC Brushless Motor Details
Specification:
Model : D2830-3200
KV (rpm/v) : 3200
Voltage (v) : 11.1
No Load Current (A): 2.2
No Load Speed (rpm) : 36000
Load Current (A) : 16.0
Load Speed (rpm) : 4300
Recommended ESC : Turborix Advance 30A ESC
Propeller : 1047
Pull (g) : 410
G/A : 25
Weight : 50g (±5g)
Packaging Weight : ~110g
it was 3200 per volt of course.
Too much for this acft?
Old 05-06-2008 | 10:44 AM
opjose's Avatar
As spiral says, that motor produces a lot of RPM's but much lower torque than say a 950kv motor.
That motor could be used on that plane, with a reduction gear drive, but I do not know if you have the room to put all of this in the cowl.
A 3-1 reduction gear drive system would put you where you want to be with that plane. You could also increase the prop diameter for more thrust too.
Old 05-06-2008 | 10:48 AM
Thanks. So a 950 would be a better fit? I'll save the 3200 for a higher performance model as i progress. Right?
Old 05-06-2008 | 10:52 AM
Missileman's Avatar
ORIGINAL: wickman11
Right Spiral.
Here are the specs:
Specification:
Model : D2830-3200
KV (rpm/v) : 3200
Voltage (v) : 11.1
Propeller : 1047
Pull (g) : 410
G/A : 25
Weight : 50g (±5g)
With the recommended 11.1v lipo that would be in excess of 33,000 rpms. you want somewhere near the 10,000 or so rpm range with an airplane.
Edit: The specs for that engine are confusing, it recommends a prop and battery, gives a no load rpm of 36,000 rpm which is just about right then give a load rpm of 4,300. If that is true this is a very weak motor to drop that many rpms under load and 4,300 rpms is too low for most airplanes. Very confusing.
Old 05-06-2008 | 11:31 AM
spiral_72's Avatar
ORIGINAL: wickman11
Yea, I'm afraid so. I just don't think you will ever be able to use that motor on that plane unless you run a gear reduction (as suggested by someone). Save the screamer for a delta wing or something.
These brushless systems are pretty expensive... I bought a Turnigy 950kV motor from Hobbycity.com or hobbypeople.com don't remember which, but it was $18. Believe it or not, it's turned out to be an absolute fantastic motor. I can't believe it was that cheap. I think the motor you will require is also known as a "400 size".
Seriously consider the balance leads on the battery and ESC though. I'm not sure what the cost difference will be.
Old 05-06-2008 | 11:41 AM
opjose's Avatar
ORIGINAL: spiral_72
As Missleman pointed out there is a serious RPM drop with the recommended prop. I wonder if the motor provides sufficient torque for any direct drive, short of a DF setup?
ORIGINAL: spiral_72
Yup, most the "brand name" motors are made in Asia anyway.
These no-namers may have slightly lower efficiencies, but for the price they have been fantastic for me.
Old 05-07-2008 | 07:23 AM
You guys have been very helpful. This sort of forum is exactly what a newbie like me needs to get started correctly.
Here is a motor I am looking at for this 29OZ VMAR Bird Dog with the stats. Does this seem to be a good fit?
TR 28-30B 14A 1050Kv Brushless Outrunner
Model: TR2830-1050
Max Eff: 12A
Max Load: 14A
Kv: 1050
Weight: 57.9gr
Pull: 400~900gr
Prop: 10x5 or 10x6
Voltage: 6~10v
No Load Curr: .9A
Thanks again
Old 05-07-2008 | 09:38 AM
Missileman's Avatar
Plenty of power, right speed, add a 25amp ESC, a 3s lipo and a 9X6 or 10X5 or so electric prop and you should be set.
(I know the max load is 14amps, I suggested a 25amp ESC so it will stay cooler, a smaller ESC will run hotter)
Old 05-07-2008 | 09:55 AM
Perfect. I'll go for that.
