Reload this Page >
Fuel Leak Inside Plane
Old 05-11-2008, 03:06 PM
pkevinb
Default Fuel Leak Inside Plane
I had a fuel leak inside my plane yesterday and need some help. I know how to take care of the wood, but the fuel is all over the battery, switch, receiver, and servo wires. Can anyone offer any tips on how to best clean up the electronic parts, and will everything be safe to use.
Any help will be appreciated.
Old 05-11-2008, 03:16 PM
DMcQuinn
My Feedback: (13)
Default RE: Fuel Leak Inside Plane
The electronics generally survive a fuel soaking pretty well. I'd wipe everything down with some detergent and water just to get the oil off. Battery and wires will be unaffected. If the switch got soaked, you'd like to get the oil out of it. I'd remove it and swish it around in some alcohol and then let it dry out.
Old 05-11-2008, 07:41 PM
horace315
My Feedback: (15)
horace315's Avatar
can use electromotive cleaner they sell it at radio shack or almost any electronics dealer.
Old 05-12-2008, 06:43 PM
red head
Auto parts stores also sell electronic cleaner, just be carefull as they usually put the brake and carb cleaner there also and you don't want that. I keep a can of electronic cleaner on my work bench and use it often, just be carefull not to spray it on clear plastic ( canopies). ENJOY !!! RED
Old 05-22-2008, 08:18 AM
speedair
wipe off as much as you can and leave it to dry properly
