 Field box with battery, or individual battery powered >
Old 10-15-2008 | 03:28 PM
Default RE: Field box with battery, or individual battery powered
hi all it i new to the board nice to meet all of you
Old 10-15-2008 | 04:03 PM
ORIGINAL: da Rock
Get rid of all the wires. The one to the glow starter and the one to the electric starter (if you use it). Sure, you can come up with safety rules to follow to make those wires less probable to get caught in the prop, but if they aren't there to get caught........... If they aren't there, the really big benefit is mobility. Where you can easily start the plane is wherever the plane is.
I a relative newcomer and in the 8 months I've been flying have come to the same conclusion. I bought a box with a panel, 12V motorcycle battery, starter and electric pump. You've got to be real careful with the cords and I'm going to replace my corded glow starter with a battery type. Will probably still hang on to the other and keep the 12V charged because I like the meter on the panel and it let's you know instantly if a broken plug is why the engine isn't starting.
Sullivan makes a battery pack that will fit my starter and uses 12 1.2V 1500MaH sub C's. Probably going to get those as well so that I've got no cords running to the front of the plane while starting it.
Old 10-15-2008 | 04:40 PM
opjose's Avatar
ORIGINAL: Bob Mitchell
Sigh....
Read the prior posts... a much better way to do this is to use the racing packs...
See this thread which has pictures of a typical setup....
[link=http://www.rcuniverse.com/forum/m_8019362/tm.htm]Click me please![/link]
Old 10-15-2008 | 05:38 PM
opjose
Thanks for posting the pictures to that battery mod for the starter
I just have 1 question.
Where can I get those batteries at a reasonable price?
Radio Shack want's $28.99 each pack
Vegas/
Old 10-15-2008 | 05:40 PM
Jetdesign's Avatar
My Feedback: (8)
As strictly an OS user the only power I need is from my glow starter, which is rechargeable. I keep that and a chicken stick in my cargo pocket and can start my plane anywhere - if it cuts out during taxi, or if no one's around and I need to start on the field, I can. If it doesn't start right up, something needs to be worked on, and avoiding doing the work and forcing it to start with an electric starter could be catastrophic.
Old 10-15-2008 | 08:52 PM
  #31
opjose's Avatar
Go to Tower's web site... www.towerhobbies.com
Type in " Battery 7.2v " into the search...
Have fun!
Old 10-15-2008 | 09:35 PM
  #32
My Feedback: (-1)
Joe, you haven't been in the hobby long enough to have your glow battery start loosing some of it's juice and surprise you yet. You haven't seen what the weather changes can do to your engines, sometimes they just don't want to start when it gets cold. Sometimes you not only need A starter but A few drops of lighter fluid just to give them A kick. Weather changes can and often will turn your 55 and 120 AX into A beast. Stay in the hobby long enough and you will be walking the line asking to use A driver and starter at some point. In another 20 degrees or so I will be opening up my high ends for the winter flying.
Old 10-15-2008 | 09:45 PM
  #33
Jetdesign's Avatar
My Feedback: (8)
ORIGINAL: Gray Beard
Sounds like it might be time to dust of that starter then...thanks for the tip!
Old 10-15-2008 | 10:21 PM
  #34
ORIGINAL: opjose
Have fun!
ORIGINAL: opjose
Have fun!
I come up with Team Orion Supercharge 7.2V 1600mAh Side by Side
Qty Discount Available
Just a couple dollars less then RS wants so I may as well use a small square 4 amp jell type I have here and make a small wooden box mounted under the starter
Vegas/
Old 10-19-2008 | 10:15 PM
  #35
ORIGINAL: tessmar
I just completed the transition to the Hobbico (Powercore) portable setup. The battery is half the size of the one for the flight box yet is more powerful. It definitely spins my starter better than the flight box battery. I
You have the hobbico part number?
I went through the site and catalog and can't find)POWERCORE)
Vegas/
