Hook and Loop Velcro >
Old 05-30-2003 | 05:02 AM
Default Hook and Loop Velcro
Which side is hook and which side is loop on velcro
Old 05-30-2003 | 05:21 AM
dioncuda's Avatar
hook is the hard side,loop is the soft side.
i think. well maybe its the other way around. its to late to think. lol
Old 05-30-2003 | 08:30 AM
Could it be as simple as the hook side has the little hooks and the loop side is the woolly side?
Maybe
Old 05-30-2003 | 08:36 AM
rajul's Avatar
Moderator
My Feedback: (58)
The loop side is the one that feels like wool. The hook side is the one that feel like a rasp. If you are wrapping it around a curve, always use the loop as it is flexible. Also use velcro with heavy duty adhesive. GP carries them but you can get longer lengths elsewhere, probably cheaper too.
Old 05-30-2003 | 08:39 AM
So it was that simple
now we know for sure.
Old 05-30-2003 | 08:49 AM
Jim C.'s Avatar
you've got to be kidding... right???? just look at it and you can tell...........
rajul's Avatar
Moderator
My Feedback: (58)
Velcro is a great engineering material. I use it to secure batts and receivers. I've seen some posts here using velcro to secure wings too.
Old 05-30-2003 | 04:36 PM
Default hook and loop velcro
Thanks guys for the input! In the future I'll just be asking GraupnerFan. He seems to know everything! LOL
Old 05-31-2003 | 02:32 AM
Sorry, but Minnflyer is the one who knows everything.
By the way, did you know that velcro was fashioned after a small "burr" that grows wild? I remember getting them on my clothes as a kid. They're small round brown balls that are covered with "hooks", and they stick to the weave of clothes like heck. Real hard to pull off.
Dennis-
Old 05-31-2003 | 02:52 AM
Default velco hook and loop
Yea that's right Dennis. I grew up in a house built on a small sand hill and we had those every year... guess I was the loop.
Old 05-31-2003 | 03:08 PM
minnflyer, a.k.a- encyclopedia!
all hail king minnflyer hehe :stupid:
Old 05-31-2003 | 04:43 PM
OK, since someone else brought it up...
I just relocates the battery pack in my Ultra Sport 40+ to the fuselage, just aft of the wing saddle. Because of space limitations, I reconfigured my battery pack from flat to square. Not much room here, so I applied some "Industrial Strength" velcro to the fuse floor and to the battery pack and stuck it in. I did put a chunk of foam between the top of the battery pack and the control rod sleeves. Not alot of pressure on the sleeves of course, I just wanted something to keep the Velcro pressed together. A little dab of silicone adhesive between the battery and the foam and one were the foam sits against the control rod housings and I think I'm OK.
Will the velcro provide any sort of vibration dampening between the fuse and the battery pack? I did not have room to wrap the foam right around the battery.
Old 05-31-2003 | 09:58 PM
I guess the velcro might supply some damping affect, but i wouldn't worry all that much about vibration and the battery pack. I mean, I DO wrap mine whenever possible, but have never seen damage on an unwrapped one.
It IS important to wrap the tank and receiver though!
Dennis-
