Looking for a post on cutting a cowl
I had seen a post on cutting a cowl that showed taping strips of paper or posterboard to get the layout to transfer to the cowl. I have lost that post. Does anyone know how to retrieve it. Thanks
bingo field -
Nice
I never even thought of that approach to line-up the proper areas for the engine. Excellent idea, seriously! I'm cutting a Piper Cub cowl (Hangar 9 .40 model) after deciding to place a Saito .62 in it, however, I can't get the cowl over the engine to even take this approach right away.
What I'm doing before hand (now that I'm going to use your approach) is to use a manila folder, like you, and create the initial "hole" for the 4-stroke to exit the cowl. THEN once I get the bulk of the engine taken care of I think your approach to finding the proper holes for the high/low adjustments and the glow plug are a perfect approach. Here's the image of my template for the cowl of the 4-stroke. Saved me a lot of hassle having that set up before I began.
Nice
I never even thought of that approach to line-up the proper areas for the engine. Excellent idea, seriously! I'm cutting a Piper Cub cowl (Hangar 9 .40 model) after deciding to place a Saito .62 in it, however, I can't get the cowl over the engine to even take this approach right away.What I'm doing before hand (now that I'm going to use your approach) is to use a manila folder, like you, and create the initial "hole" for the 4-stroke to exit the cowl. THEN once I get the bulk of the engine taken care of I think your approach to finding the proper holes for the high/low adjustments and the glow plug are a perfect approach. Here's the image of my template for the cowl of the 4-stroke. Saved me a lot of hassle having that set up before I began.
I got it pretty close using brown wrapping paper: [link=http://www.rcuniverse.com/forum/m_7276786/mpage_5/key_/tm.htm]Post #119[/link]
And, I also had some issues getting the cowl over the engine. I ended up with the front open more than I wanted. Some guys have gone back in and bolted the front/dummy engine in after the cowl is mounted.
ORIGINAL: gaRCfield
I just downloaded the manual for the 90-120 Yak at aero-works.net and it's got a big, color photo section for cutting and mounting the cowl with all the tricks.
Great!!! I don't know how to do two quotes. Thanks to CGR and gaRCfield. I did look at the manual so I saved it. Dick where do I find the video of Minnflyer? BTW just made some homemade English Muffins sending some over to you guys, enjoy. OH!! I better send some to Minnreefer.
KY
ORIGINAL: goirish
If I want to quote a couple of different parts of someone's message, without backquoting the entire thing, I'll usually just cut out what I don't want and type in the extra start/stop quote marks. You can freely edit within the quote box just like you can in the text of your own message. Just "quote" the whole thing, then cut out what you don't want, insert you own text where you want it, then add the extra quote codes to set up a second or even a third quote box.
Note that the software is looking for the square brackets around the word "quote" to start and stop the quoted lines, and that I added an extra space in my example (bolded above) to prevent them from being picked up as markers in THIS message. You also have to remember to use the forward slash "/" for the "ending" quote mark.
Well lets see if I can do that
It's easy. The software looks for the combination of [ quote ] and [ /quote ], takes everything between the two and draws the box around it to set it off. It also is programmed to insert the word "ORIGINAL" and the name of the poster. Every time you type in the [ quote ] and [ /quote ] it will create an additional "quote" box.
Hummm!!! I didn't get the 2nd quote box.
ORIGINAL: goirish
ORIGINAL: goirish
I wish you guys wouldn't make it look so easy. Do I click on the quote and then put the brackets around it?
ORIGINAL: goirish
[quote]
boy did I screw that upI will get my grandson to show me how to do it. Thanks, sorry for taking this off topic.
You can go here http://www.rcuniverse.com/forum/forumid_72/tt.htm and practice all you want. That's what it is for.
To be honest I feel a little stupid that I can't seem to grasp the concept. I will go there and learn to do this very complicated thing (yea)
My Feedback: (8)
You'll kick yourself once you learn it.
ORIGINAL: goirish
You got it. Where are you going to school . You know the funny thing is I have all kinds of education. All kinds of letters after my name and I can't do this silly little thing.
No worries, I'm not the best at it either, and I AM starting to study rockets!
[/quote]
Move over gaRCfield I got it and I am going to start building rockets.
