RX, Tx and battery
Will all of this stuff work together?[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMYL6**&P=0]Tx and Rx with Tx battery[/link] [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWX97&P=ML]Rx battery[/link] [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXL331&P=V]charger[/link] [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXL332&P=V]leads for charger[/link]
The radio you have listed has everything you need to fly, Why are you upgrading the receiver pack and charger?
As for an answer, yes they will work together, but they are not the best combination.
What do you indend to use this radio system on? It matters!
All the items you are looking at would work together. You could pick up something that includes everything you are looking for in one complete system.
Airtronics VG400, Futaba 4YF are two instances that have the TX, RX, servos and the applicable battery packs and chargers and for quite a bit less cost.
CGr
CGr
Then any basic system as I showed would work with the included battery pack and charger.
If you want to upgrade, well, that's fine, but for a basic setup, the Airtronics or Futaba systems are just fine. I've used both, I prefer the Airtronics (personal choice) but both will work just fine.
As for the Airtronics, the basic servo, the 94102Z is a fine servo and I have a bunch of them and fly with them regularly. There is nothing wrong with the Futaba's but I just happen to prefer the Airtronics.
CGr
CGr
Yep. So does the Futaba... and I would think so does the Hitec... but the description on Tower does not say charger.
Your choice. As I said, I prefer the Airtronics.. I was "broght up" on Airtronics. This becomes a " Ford vs. Chevy" argument where the Futaba gestapo would spit on Airtronics users..
(just kidding, Minnflyer.. ) but for basic systems are just that and work just fine.
CGr
(just kidding, Minnflyer.. ) but for basic systems are just that and work just fine.CGr
My Feedback: (16)
ORIGINAL: 2STROKED
You need the one that has the #322 servos
MA
Futaba and Tower Hobbies are exactly the same, and they both include crystals
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEFJ4**&P=0]Futaba 4YF 4-Channel [/link]
[link=http://www3.towerhobbies.com/cgi-bin/wti0161p?&I=LZ0540**]Tower Hobbies 4-TH 4-Channel w/4 TS53 Std Servos[/link]
Here is the Airtronics, does not include crystals
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPV52**&P=0]Airtronics VG400[/link]
Hey Dick
We are snowed in. Took the snowblower this morning and now we have another 6-8". Working on my Big BingoI put a magnum 180 4 stroke in that puppy. Just starting the covering and my wife is very good at it. Must be that old seamstress in her, she knows where to nip and tuck. Looking at all the post you have been busy. It is about our bedtime isn't it?
Also found [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXANT6**&P=0]this[/link] package. Would it work no problem? It comes with hs-322 servos. Also does it come with ALL the crystals i need?
My Feedback: (16)
This will be good for your trainer
Yes the crystal is included but you need to tell them what channel you want see the two asterisk
One Receiver Crystal HRCL01**
here are the Channels they have in stock
14, 16, 17, 18, 20, 31, 34, 40, 54, 56, 57, 58, 59 and 60
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: shd3920
Ken
MA
ORIGINAL: 2STROKED
I have a Hitec myself and it is very good
W8YE is right about the combo. One problem with the first one you listed is the servos were too small (HS-81), another thing to pay attention to is the type of Rx in the package. The first one had the Mini6S which is a single conversion, and I would suggest a Dual. I was bit by buying the Min6S to try to save some money, but I had a lot of problems with glitching. I switched it to the the Supreme IIs and have been very happy.
Before you purchase, you may want to think about how far you want to go in the hobby. If you plan on buying a couple of planes, then you may want to think about a computer radio with more than 4 channels, possibly 5 or 6. If so, then you may also want to look at the deals that Hobby People are having. The computer radios will allow you to make trim adjustments digitally and they will be stored to a model that you can recall later, so if you fly several planes, you can choose which plane on the radio and all of the previous trim adjustments will be recalled. (this goes for servo reversing, end point adjustement, and others). Also one of the features is Exponential, which helps take out some of the jerkiness when you are first touching the sticks.
Some things to consider...
You came to the right place,
Curtis
Curtis
MA
ORIGINAL: RCKen
This information is not correct. Airtronics ALWAYS includes the crystals in their radio you do not need to purchase the crystals seperately like you have for a Futaba radio.
Ken
ORIGINAL: shd3920
Ken
Features as listed in Towerhobbies:
INCLUDES: One Futaba 4YF 4-channel FM radio system with NiCd batteries, charger
frequency flags, neck strap, servo tray, switch harness, four
S3004 servos, servo mounting hardware, transmitter and receiver
crystals and R168DF Receiver
