foam safe spray paint?
Enamels are typically safe to use on foam...but they can be heavy if you use a lot of it...spray in light coats and as few as possable.
Just to be sure though, I would do a test on a scrap piece of foam before shooting the whole plane/wing, etc.
I repainted my F-27 Stryker with my airbrush, and I used water thinned latex paint. When it dries, it is quite light. You may be able to do it with a brush if you thin it right.
There is a Minwax Polycrylic sold at major harware stores. It is water based. Use this as a base coat and sand with a fine grit sand paper between coats. This will seal the foam and allow you to use most any spray paint. The Testers works well.
I like the Minwax base coat because you can sand off the beer cooler foam look and make a smoother finish.
IN
ORIGINAL: jimmyjames213
is their a foam safe spray paint (can, not airbrush) for polystyrene
im trying to paint a gws tigermoth....any other method that wont kill the weight of the plane?
Good paint to use on foam is Krylon Kids Tuff. Non toxic and the propellant won't attack foam. Excellent coverage and no primer or sealant needed.</p>
