 Battery Installation >
Old 06-07-2009 | 12:22 PM
Default Battery Installation
When installing the battery in a glow plane is it necessary to pad it? Why?
I understand padding the electronics and fuel, just not sure on the battery.
Thanks for the replys,
KW_Counter
Old 06-07-2009 | 12:25 PM
DavidAgar's Avatar
My Feedback: (108)
Default RE: Battery Installation
Is it necessary, no, is it a good idea, yes. It protects the battery from vibration and damage in the event of a crash. It also should be wrapped and securely padded in the plane so it cannot move around. Good Luck, Dave
Old 06-07-2009 | 12:27 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Yes you should pad it. The vibrations from the engine can affect the solder joints on the battery tabs and wiring, and could cause a mechanical failure in those joints.
Ken
Old 06-07-2009 | 03:00 PM
The components inside the battery cells don't like vibration either.  Pad the pack well, and protect it with a plastic bag if it mounts near the fuel tank.
