 Continuous tone from receiver >
Old 02-07-2010 | 08:42 AM
rmsingh's Avatar
Default Continuous tone from receiver
I could use some help.
I started a new thread here, but this posted in this forum http://www.rcuniverse.com/forum/m_79...mpage_2/tm.htm
<quote>Ok, so I followed all instructions and got to the point of connecting the battery. The receiver sounded various tones as expected, but as soon as I turn on the transmitter, and operate the controls, I get a long continuos tone coming from the receiver. The tone would continue even if I turn off the transmitter. All controls operate as expected i.e. rudder, ailerons, throttle and elevator. What does the tone mean? I cannot find any references in the manual or this forum.<quote>
<quote>Could this be the problem? http://www.rcuniverse.com/forum/m_7613275/tm.htm If so how do I solve it? Re-bind the transmitter/receiver?<quote>
Transmitter - DX5e
Receiver - AR500
Plane - Eflite apprentice 15E
</quote></quote></quote></quote>
Old 02-07-2010 | 01:33 PM
Default RE: Continuous tone from receiver
You're probably hearing whining from your servos. Perfectly normal to hear a soft, high pitched tone. FYI, NEVER turn off the transmitter while the battery is connected. I fly with a couple of guys who have the scars to prove that this is a very bad idea. The motor can go to full with no transmitter input.
Old 02-07-2010 | 02:04 PM
rmsingh's Avatar
Thanks Tim. I won't worry about it. Time to work up the nerve to take 'er out for a test.
Old 02-07-2010 | 02:30 PM
Sounds like this is an electric plane ?
The tone is from the ESC. Turn on Tx now
lower the throttle stick and trim all the way
down.
Now plug in the planes battery, should hear
one beep. Next raise the throttle stick to full
power (up), should hear another beep.
Now lower the trottle all the way again, you should
here a number of beeps . 3 beeps for a 3 cell battery
4 beeps for a 4 cell etc..
Now the ESC is armed and the prop will spin when
throttle stick is raised.
Bob
Old 02-07-2010 | 02:50 PM
rmsingh's Avatar
The throttle works properly, the motor spins up and down with the throttle stick, in fact everything works. But sound is there and is more pronounced when the aileron servos are operated.
ORIGINAL: dignlivn
down.
Bob
Old 02-07-2010 | 02:54 PM
faulknej's Avatar
My Feedback: (9)
Is the sound as loud as the beeps when you turn it on? Or lower, like a hum?
Old 02-07-2010 | 04:09 PM
rmsingh's Avatar
It is not like a beep, more like a high pitch continuous tone.
Old 02-07-2010 | 04:27 PM
Could be the Aileron servo ?
Is it binding ?
Is there just one servo for the Ailerons ?
Try unpluging the Aileron servo (s),
does the tone go away ?
Try un hooking the aileron linkage and see
if the servo is centered.
Bob
Old 02-07-2010 | 04:55 PM
rmsingh's Avatar
It is not the aileron servos. The sound is there whether the aileron servos are connected or not. It is just more intense when they are connected. I already tryed re-binding the receiver. There are 2 servos for the ailerons using a Y connector. The servos is centered. Everything works fine, another user on this forum assembled the same kit and is having the same problem. Could this be a bad receiver batch?
Old 02-07-2010 | 06:00 PM
faulknej's Avatar
My Feedback: (9)
Big question is, does the noise affect the flight of the model? If not, no worries. Isuspect a capacitor or something in the ESC making noise. If the plane works ok, just fly it.
Old 02-08-2010 | 06:33 PM
rmsingh's Avatar
Yea I will... I sent an email to HorizonHobby support, I will post ay reply.
ORIGINAL: faulknej
Old 02-08-2010 | 11:57 PM
JollyPopper's Avatar
I just bought a whole lot of stuff from a guy getting out of the hobby. Included were three airplanes with R607FS receivers in them. Two of them are dead silent when in use, but the third one has a rather loud hum/buzz in it any time it is turned on. Doesn't matter whether the transmitter is on or not, if the receiver switch is turned on, the receiver hums. Everything works fine, so I have not delved into the cause, but I will try to figure out what causes it before I fly it.
Old 02-10-2010 | 06:28 PM
rmsingh's Avatar
I got a call back from HorizonHobby support... apparently the sound is normal and comes from the motor. Case closed.
