 Sig four star rebuild >
Old 03-08-2010 | 05:39 PM
My Feedback: (76)
Default Sig four star rebuild
Ok I am rebuilding my Sig Four star 40 from a recent mishap on a landing and i have decided to stip it and recover it what is the best way to remove all the covering
Old 03-08-2010 | 06:09 PM
Default RE: Sig four star rebuild
A heat gun makes it fairly easy once you have an edge to work with.
Old 03-08-2010 | 06:24 PM
I though that an knife through the covering gave the edge
Don
Old 03-09-2010 | 09:52 AM
A heat gun for the initial removal.
Then you will need a combination of Acetone and sandpaper.
Use the Acetone in a well ventilated area - outside, if possible.
Good Luck,
KW_Counter
Old 03-09-2010 | 02:30 PM
SeamusG's Avatar
Just stripped my 4Star60 kit. Heat gun, mini needle nose pliers and acetone. Be careful when you're tossing the plane over to get at pieces of film - the turtle deck stringers break very easily.
Just thought of a potential issue. Ultracote (my covering) has clear adhesive - the color is in the top material. Monokote has colored adhesive with a clear top material. You will leave color behind with Monokote - clean up with Acetone will be necessary and like not entirely successful.
