Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > CEN Racing
 Head Gasket Material for NX-76 >
CEN Racing This forum is to discuss all CEN Racing products.
Old 01-09-2006 | 03:09 PM
Default Head Gasket Material for NX-76
Can anyone tell me what material the head gasket in the NX-76 is made out of? I am reffering to part G70357-03.
I ask because I pulled the head off last night and noticed there wasn't any gasket. I've run about 3/4 gallon thru the truck and there were no apparent problems.
Joe
Old 01-09-2006 | 03:43 PM
craigb's Avatar
Default RE: Head Gasket Material for NX-76
Joe I don't have a NX-76 but all the engines i have had have a aluminum head gasket... also most the time it looks like theres non there but its hiding inside the grove on the head... have a look! it should be there somewhere
Old 01-09-2006 | 03:46 PM
Thanks much. I bet that's it then. I did notice an aluminum piece there but I was think head gaskets like a car when you have some fiber type of material with maybe a metal ring, etc.
Old 01-09-2006 | 08:54 PM
I didn't notice one either when I put on my new cooling fin from nova....
Old 01-24-2006 | 02:38 AM
There should be one there, it's called a "Shim", there is one on every engine, if you run it without it, theres more compression cause it's closer to the piston, some people do it if they know how to properly tune.
Old 02-01-2006 | 02:24 AM
Would having a cracked/broken exhaust gasket cause problems in the normal function of the car? I have a CEN Fun Factor Rally (4WD).
I stripped the car to clean it and put it back together, with a broken gasket, and when I ran it after reassembly - it was very sluggish.
Just curious since I realize that backpressure is kind of important in 2-stroke engines.
Old 02-01-2006 | 07:28 AM
hmmm.....how did you crack it, and yeah it might be sluggish cause you might be getting air
Old 02-01-2006 | 09:55 AM
Well I had mud EVERYWHERE from a... shall we say "accidental".... roll over into some mud and stupid me wanted to remove it just so I could clean everything. Well I tugged a little too hard when it wouldn't budge (it was stuck to the manifold) and it tore in half like toilet paper.
Sadly, no one in my area really carries CEN parts... But I have had great success with http://www.toyhaus.com - it's just that waiting that sucks ya know?
ORIGINAL: ViperSkull
Old 02-01-2006 | 10:45 AM
I also rplaced the gasket on my ff i thought the heat caused it to break and the noise that it made when i fired it up was unbeleivable. It was like a engine that had never been tuned
Old 02-04-2006 | 01:40 AM
wait, are you guys talking about head gaskets or manifold gaskets, your going from one to another.
Old 02-04-2006 | 02:42 AM
I specifically meant exhaust manifold. Since it was going to be a couple days before I get my parts, I took a bit of crazy glue and glued the gasket together then used a bit of hi-temp silicone RVT around the gasket and reinstalled it - seemed to work just fine! I should be ok for the time being.
Now I just have to figure why my electronics went insane tonight, sending my car into a flurry of donuts then straight into a wall. Interesting enough, there was no visible damage, but my diffs are locked. Oh dear.
