YS 61AR Mounts
Old 02-15-2014 | 02:44 PM
My Feedback: (43)
Default YS 61AR Mounts
I just picked up an Atlanta and a YS 61AR with header for a steal. The YS is perfect inside! The Atlanta is setup for a back plate mount??? At least that is what it looks like. DId they used make a back plate mount for 61s back in the 80s? The firewall has the rubber type Lords mount attached that are threaded to bolt the ears of the spider type back plate mount.
JEff
Old 02-15-2014 | 03:13 PM
My Feedback: (44)
pretty common back then still works fine.very easy to service as the lord mounts are common....
Old 02-15-2014 | 03:43 PM
My Feedback: (43)
Who made them?
Old 02-15-2014 | 03:51 PM
doxilia's Avatar
Dave Brown
Old 02-15-2014 | 04:16 PM
Gator made a "back plate" mount. Sounds like thats what may be is in your Atlanta.
Dave
Old 02-15-2014 | 05:10 PM
My Feedback: (57)
Jeff,
If your are in need of a back plate mount for your engine. I have one that was on a YS 61. It mounts on top of the back plate and uses the same screws that holds on the back plate. My camera has dead batteries in it..... But I will get you a picture of it. If you can use it.... it is yours.
Mark
Old 02-15-2014 | 09:19 PM
Mark,
I'm interested in the back plate if Jeff declines.
Also looking for a YS61RE AR type.
thx
B
Old 02-16-2014 | 08:40 AM
My Feedback: (43)
Hey Mark, I am certainly interested in it. I will take it and if it works great, if not, I will pass it on to skybuster, sound fair? If you ever need anything, let me know, I would be glad to try and help. THANK YOU!!
Jeff
Old 02-16-2014 | 10:04 AM
My Feedback: (57)
Jeff,
Send me a email with you address and I'll send it to you.
[email protected]
Old 02-16-2014 | 11:13 AM
My Feedback: (44)
sullivan #278 on fleabay
Name:	sullivan soft mount 278.jpg
Old 02-16-2014 | 11:22 AM
My Feedback: (44)
dave brown style on fleabay..has softer lord mounts and uses nose ring
Old 02-18-2014 | 09:13 AM
Another picture for you. Two styles here purchased in the late 80's for my Conquest IV. Hope this helps.
Doug
Name:	YS Soft Mount.jpg
Old 02-18-2014 | 10:13 AM
My Feedback: (43)
It is setup for either the Dave Brown on Sullivan since the lower engine bolts are closer together and not a square pattern like a Gator or Dubro mount.
So in the heck do you know how tight to tighten the rubber? YOu can put but so much grunt on the bolt or the rubber will tear, yes?
I have only ever used Gator or Hyde mounts.
Old 02-18-2014 | 10:16 AM
My Feedback: (44)
not much torque is needed to screw the lordmounts to the firewall. blue loctite used sparingly is enough. I finger tighten the lord mounts to the firewall
Old 02-18-2014 | 11:11 AM
My Feedback: (43)
Finger tight? I guess the bolt from the mount into the lordmount will keep the lordmount from unscrewing itself, along with the loctite. I know the lordmounts that are in there are TIGHT!!!! I have to figure out to remove those since they are old.
Old 02-18-2014 | 12:20 PM
My Feedback: (90)
Ifinney do you have model number of the Dave Brown mount you show in post #11?
Old 02-18-2014 | 12:47 PM
My Feedback: (44)
#vdtb1000 http://www.dbproducts.com/store/vdtb.htm
Old 02-18-2014 | 12:51 PM
My Feedback: (44)
people often glue them in place along with tightening them..I use blind t-nuts with a smidge of blue thread locker..
Old 02-18-2014 | 04:00 PM
jbudd's Avatar
I produced the soft mounts (back in the 88-91 time frame) now marketed by Sullivan Products (shown in post #10). Don't use any locktite on the screw threads, either on the stud/plate isolators into the blind nuts/firewall, or the screws that clamp the rear mounted plate to the rubber isolators (the external tooth star lock washers provided work perfectly), as you'll never be able to remove the isolators from the blind nuts if you do! I never had one come loose, nor did anyone tell me that they did either. It was a very simple yet robust system that worked quite well at isolating engine vibration from the airframe.
Jerry
Old 02-18-2014 | 04:53 PM
My Feedback: (43)
Well that sounds like a plan, and you should know Jerry. Do you recommend a nose ring?
Old 02-18-2014 | 05:08 PM
Jerry
Jerry,
You should come out and fly some Classic Pattern with us some time soon. We were in Lancaster this weekend.
It would be great to see you again.
Doug Woodward
Old 02-19-2014 | 08:44 AM
jbudd's Avatar
It's not needed for the mounts I sold, I know that the other mounts produced by Performance Products Unlimited (and later by Dave Brown Products) utilized a nose ring, but I know of no one that used a nose ring with my design.
Old 02-19-2014 | 08:51 AM
jbudd's Avatar
Originally Posted by 80sPattern
Jerry,
Doug Woodward
One of these days I might. I do have an old EU-1A kit and all of the legacy hardware to go with it, it'd be the 5th one for me, lots of memories there going WAY back. I still remember your crash at Mile Square back in 1987 or 1988 due to an R/C car being on your aircraft frequency! You had what, one usable component left in the wreckage? (the glow plug)! If you have the pics of that motor available, you should post them. Ouch!
Jerry
Old 02-19-2014 | 09:39 AM
Jerry,
What a memory you have!!! It was the NSRCA District 7 Championship and I was in the hunt for first. I had to fly the rest of that flight and the next round with a buddy's tipo and I didnt fare too well with a plane I had not flown before.
It still hurts to look at it. Before and after pictures for your pleasure.
Here is also a picture of my new ride.
Please try to come to the next Classic Pattern event even if you dont have a plane. You can fly mine or just shoot the poop with us. Tom McNicolas is going to start attending as well.
Upcoming Schedule:
Saturday, June 7th: 4th Annual Classic Pattern Get-Together, Riverside (Perris), Ca.
CD Robert Fish
July 12th: Lancaster 1-day Classic (Sunday 7/16 is Back-up day) CD Tony Frackowiak
September 13th & 14th Hollister 2-day - CD Jon Carter
(Combined AMA/Classic event)
Saturday, October 4th: Classic Pattern contest at PVMAC (Pomona Valley Model Airplane Club)
CD Call Orr
Saturday, November 8th: Lancaster 1-day Classic (Sunday is Back-up day) CD Tony Frackowiak
(Check RC Groups as we have more Classic Pattern traffic over there including the build thread on my Conquest)
Hope to see you soon.
Doug
ID:	1970106   Click image for larger version
ID:	1970107   Click image for larger version
Old 02-19-2014 | 02:29 PM
My Feedback: (121)
Hey Doug,
photo #2 is just sad - who was the wise guy who put the bottle of CA and Kicker in the photo! One of the many pluses of the new radio technology!
Very Nice Conquest, is that one of Don's (RCAIIR) kits? What's in it for power?
-Will
