Recommend a Pattern ARF .46 to .61
Old 01-02-2006 | 11:36 AM
My Feedback: (7)
Default Recommend a Pattern ARF .46 to .61
Can someone recommend an ARF pattern flyer. It doesn't have to be the perfect pattern plane. In addition to the .46 and .61 I have an OS FS 70 4 stroke. Any plane for one of these engines will be ok. But I do not want something that is real fast.
I have average flying skills. For the past 2 seasons I have been flying a .46 Ultra Stick from Horizon and electric sailplanes.
It has to be an ARF because I just do not have the time to build a kit this winter. Next winter I will be retired and can build a pattern kit.
So can someone please recommend an ARF pattern starter.
Thank you. bob
Old 01-02-2006 | 02:04 PM
8178's Avatar
My Feedback: (17)
Default RE: Recommend a Pattern ARF .46 to .61
At $99. the SPA approved Tower Kaos 40 ARF is hard to beat and will fly the “Classic Pattern” pretty well. With a 46 it flies like a low wing trainer.
Here’s a link to a list of “Classic Pattern” aircraft kits and ARFs http://www.rcuniverse.com/forum/m_3053513/tm.htm
Old 01-02-2006 | 02:06 PM
Bob,
If you don't want something that flies fast, you probably don't want a classic pattern plane - they are commonly referred to as "ballistic pattern planes" for good reason. The modern F3A type planes would probably suit you a lot better. There's currently a thread in the generic pattern forum "Please suggest one of these for first pattern plane" that should give you some ideas.
Good luck!
Tim
