AURORA 45
Old 11-09-2006 | 05:24 PM
8178's Avatar
My Feedback: (17)
Default RE: AURORA 45
Jim,
From the pictures and drawing I think you might be able to use the front section of a Blue Angel canopy and they are available.
Old 11-14-2006 | 08:38 AM
well I guess that I have been stuck with 3 sets of plans, I have yet to hear from roary_m, ppljr, and prop_buster.
Old 11-14-2006 | 04:18 PM
Deadstik's Avatar
My Feedback: (8)
Chris,
Just got the plans.... they look great.... looks like Ill be doing a foam wing when I get to it.... same type thing I did for 8178's Blue Angel... but.. it will be a while... there are 4 major projects ahead.. but.. I'm going to get to it eventually.... as well as an Aurora...
Thanks for your effort in getting the plans done.... I'm sure the other guys will pony up......
Dan
Carolina Custom Aircraft
Old 11-17-2006 | 09:15 AM
Dan, sent you a PM.
Old 11-23-2006 | 11:11 PM
My Feedback: (8)
Just received an email from Singapore Hobbies .... Yikes!!!!!
Dear James,
Sorry for the late reply.
The canopy of the Aurora 45 is available. The price is S$23.70. Shipping
to Canada via reg. airmail is S$19.00.
Thank you.
Best regards,
Ronald Yong
Singapore Hobby Supplies Pte Ltd
150 South Bridge Road,
Fook Hai Building, #B1-23.
Singapore 058727.
Tel: (65) 6532-1993
Fax: (65) 6535-7866
http://www.singahobby.com
All prices are quoted in Singapore Dollars.
-----Original Message-----
Sent: Saturday, November 11, 2006 12:28 AM
To: [email protected]
Are there any kits, cowls,canopies available for the Aurora 45 or Aurora
45s?
What would be the price to ship to Canada?
Old 11-23-2006 | 11:18 PM
  #31
rainedave's Avatar
That's $27.50 US or $31.35 CAN total.
Old 11-24-2006 | 07:26 AM
  #32
My Feedback: (8)
Thanks, Dave ... the Singapore Dollar exchange still doesn't make it a very enticing offer. Does RCU want to collect a fund for it?
Just opened up my Aurora 45 plans. Wow. My hat .... or tuque eh! to 8178 for being able to make the Blue Angel based on plans like this. How's anyone determining the tip airfoil profile?
ORIGINAL: rainedave
Old 11-24-2006 | 08:52 AM
  #33
Deadstik's Avatar
My Feedback: (8)
Jim,
There a couple of ways to "derive" the tip airfoil. For me, the easiest way is to first copy the root rib airfoil shape. You must be careful to make certain exactly what is shown on the plans. IT USUALLY is the airfoil AT THE WING/SIDE OF THE FUSELAGE. If this is the case you then have to measure the distance from LE to TE AT THE WING ROOT and the distance for LE TO TE AT THE WING TIP. Then you bring up your original scan from the side view/fuselage in the TILEPRINT software program. TILEPRINT allows you to scale up/down anything just by drawing a line and giving it a KNOWN DISTANCE. You print out the first one given the root distance and the second one given the tip distance. Instantly you have the root and tip templates. Same procedure is used for the stab.
Tile print supports the follwing formats: Bitmaps (*.bmp;*.dib), GIF Images (*.gif), JPEG Images (*.jpg;*.jpeg), Metafiles (*.wmf;*.emf) and Icons(*.ico;*.cur). Tileprint was written by a fellow RCU member who usually is in the 1/2A forum areas... Great guy.. this software has saved me HOURS and really makes it easy to make wing templates/ and ribs
You can download it from at http://donatelli.net/downloads/ tileprint .zip
Hope this helps. Good luck with your project... I've got to order the Canopy.....
Dan Hines
Rougemont, NC
[email protected]
Old 11-24-2006 | 09:53 AM
  #34
ORIGINAL: Deadstik
Dan Hines
Rougemont, NC
[email protected]
Hey Dan,
Before you order a canopy, maybe we should see if there is interest in getting a group buy together to minimize the shipping costs. I am in for one if you are interested in doing this. I will also take delivery of the batch of canopies and ship them on to individuals if no one else wants to do it.
Mark
Old 11-24-2006 | 04:40 PM
  #35
My Feedback: (8)
Dan is this the same technique you used on 8178's Blue Angel. I already have tileprint, profili2 and Compufoil3D. But with the technique you're describing won't you get the same percentage airfoil thickness for both the root and tip airfoils? Too bad most kit plans don't give you the root and tip profiles.
Jim
ORIGINAL: Deadstik
Jim,
Dan Hines
Rougemont, NC
[email protected]
Old 11-24-2006 | 05:26 PM
  #36
8178's Avatar
My Feedback: (17)
Jim,
We had root and tip wing rib tracings from a MK kit for the Blue Angel.
Old 11-24-2006 | 05:31 PM
  #37
My Feedback: (8)
Thanks 8178, that's what is missing from the Aurora 45 plans. No root or tip airfoils?
Dan, if you have the plans of the Aurora 45, is the airfoil profile similar to the Blue Angel?
Old 11-24-2006 | 06:08 PM
  #38
rainedave's Avatar
If all you have is the airfoil at the fuse side and you enlarge it to the root chord, it probably wouldn't be a bad idea to make the tip airfoil about 2% thicker, or so. That's what I would do anyway. Was the BA airfoil a constant thickness?
Old 11-24-2006 | 06:32 PM
  #39
8178's Avatar
My Feedback: (17)
ORIGINAL: rainedave
The Blue Angel has a 15.5% root and tip airfoil.
Old 11-25-2006 | 03:03 AM
  #40
My Feedback: (14)
Chris,
I got the plans a couple of days ago and they look great but
there's one little problem. One of the postal worker decided
he must do the old weapon in the mailing tube test and did a
double bent to the tube. I should have asked for folded plans.
Ron
Old 11-25-2006 | 09:53 AM
  #41
Deadstik's Avatar
My Feedback: (8)
Ron,
Isn't that something ???? My tube arrived after being run over by a forklift !!!! Krinkled the plans but nothing I couldn't iron out... but.. for the prices they are charging, they should do better.... ok.. rant over..
Dan
Jim, I'm going to check the Aurora 45 plans this afternoon and see what the templates would look like.
Old 11-25-2006 | 11:36 PM
  #42
My Feedback: (8)
My tube arrived in perfect condition. Acutually this is the first drawing I've ever received in a tube. Most have been shipped flat.
Jim
Old 01-07-2007 | 09:54 PM
  #43
My Feedback: (8)
For those who are interested, dbalsa has a foam wing available for the Aurora 45 [link=http://www.dbalsa.com]Dbalsa Foam Wing Cores[/link]
Old 01-24-2007 | 01:00 AM
  #44
My Feedback: (18)
Hey..Do you still have a set of plans?? I'll take a set if you do!!
Are some of you guys scratch building??
If so let me know...I could make a mold of of the Belly Pan if anyone needs them and can't find them anywhere...
I'll probably do the Belly Pan and the Canopy...I see the Aurora60 stuff is running out of stock...No kits..No Belly Pans...Not too sure on the Canopy??
Old 01-24-2007 | 03:17 PM
  #45
Chris, I'll take a set of plans as well if you're stuck with extra. Let me know.
Jeff L
Old 01-28-2007 | 03:32 AM
  #46
Chris
I'll also take a copy, if you have one left.
DM
Old 01-28-2007 | 08:05 AM
  #47
My Feedback: (18)
Chris...Put me secondary to the other fellow's...If you run out..That's OK...I actually have a nice set of drawings...I just thought I could use a second set as a "Working Copy" for construction since you had extras...
If you run out..No Prob...I'll just get a set of mine re-printed for a working copy and save the originals...
It seems were loosing this valuable information...So at least this way we'll have a source for drawings...
Thanks for doing this BTW...A good idea..
Have Fun...
Chuck
Old 05-14-2007 | 02:23 AM
  #48
Hello Chris
I'll also take a copy, if you have any one left.
Could you please tell me the total (copying etc.) cost to post to Australia.
Many thanks
Sean
Old 05-14-2007 | 07:53 AM
  #49
My Feedback: (18)
Hey petiteway...
I never heard anything from chris...Maybe he got rid of all his sets of drawings?? Or maybe he will contact you??
If he doesn't...Let me know and I'll get you a copy of mine if you want...I need to go get a second set for myself anyhow...So this will get me off my duff..he he
Have Fun...
Chuck
Old 05-14-2007 | 08:25 AM
  #50
Sorry about that guys, I've been busy. I can do another set for anyone who wants them. I'll probably fold and mail in an envelope instead of a tube. Whoevers interested can Paypal me $20.00 if shipping in US $25.00 if shipping to Canada [email protected] I'll probably wait a week or so before I get the copies done. Sorry again about not getting back sooner.
Chris
