MK Wild Beat
Old 02-06-2011, 07:03 AM
  #126
Avaiojet
Default RE: MK Wild Beat
David,
I've been keeping an eye on your build. Great job!! I guess you decided on built up wings instead of foam?
I'm looking forward to more photos.
Keep up the good work!
Charles
Old 02-06-2011, 07:11 AM
  #127
dhal22
Hey Charles, good to hear from you. This is a actual MK kit. I think all MK kits are built up wings. Speaking of wings, I'm about ready to start some wing work on the WB.
Don, it looks like I owe you some MK model numbers.
Old 02-06-2011, 07:16 AM
  #128
dhal22
Charles, I will need you do do my graphics work for this plane sometime in the future. Your suggestions are welcome. The graphics you did for my Blue Angel were perfectly done. The Yoshioka font there was impossible for other graphics makers to match.
Old 02-06-2011, 08:41 AM
  #129
frequent flyer
frequent flyer's Avatar
David which graphics were you using? Are you using spray mask?
Old 02-06-2011, 09:30 AM
  #130
dhal22
Don, I don't have any graphics planned yet. Charles cut my Blue Angel graphics and did a very good job. Several people tried to imitate the Yoshioka font and failed. Charles had it nailed in one evening. I assume they are vinyl. My guess is I will do the plane name, some stars and maybe the MK logo.
Do you have any ideas yet?
Old 02-06-2011, 10:17 AM
  #131
frequent flyer
Oh, I was wondering which graphics those were ? Are they the MK logo? The reason I ask is that is that I do alot of custom car and mototcycle painting at my motorcycle business and I have a 36' plotter /cutter that we make graphics, signs, paint masks and so on. I was wantiing to see if I had those fonts you were referring to. I have over 10,000 different ones. No biggy, just piddling around and thought that I would check it out. Later
Old 02-06-2011, 12:13 PM
  #132
dhal22
Don, I'm having Charles do an MK logo right now. It will cover up a boo-boo on the top side of my BA aileron.
Old 02-06-2011, 12:42 PM
  #133
dhal22
Since I'm at a standstill on the BA I decided to do a little WB work. I got the 2 wings halves glued together. I used the white Gorilla glue, which I am getting to like a lot. No need for it in most places but it seemed a good place to use it here.
More to follow today.
Looks like no photo uploads right now. Maybe later.....
Old 02-06-2011, 12:47 PM
  #134
dhal22
Let's try the photos again.
ID:	1559576   Click image for larger version
ID:	1559577   Click image for larger version
Old 02-06-2011, 12:51 PM
  #135
dhal22
Here's the servos I will be using for the ailerons. They are S9150's. I grabbed these a couple of black fridays ago for $20 apiece. I like the way they are shaped for wing/aileron use.
ID:	1559580   Click image for larger version
Old 02-07-2011, 01:52 PM
  #136
doxilia
doxilia's Avatar
Nice servos David!
Say, how does MK go about building the wing given that the ribs are symmetric and taper uniformly from root to tip? There must be some technique they recommend in order to keep all the rib center-lines on the same plane. Do they just use shims under the wing bottom spar? The ribs don't appear drilled for a jig nor do they look like they had breakaway tabs.
David.
Old 02-07-2011, 04:09 PM
  #137
joefroooo
My Feedback: (10)
Dave that is a good score for the S9150 @ 20.00. I also looked at them but opted for S9551. fast speed and I can use a 6.0v pack.
Old 02-07-2011, 04:13 PM
  #138
dhal22
David, i will have to mentally revisit how i formed the wing halves. one moment.
Old 02-07-2011, 07:22 PM
  #139
flywilly
My Feedback: (121)
Not all MK kits were produced with built-up (all wood wings): the Blue Angel VR-7, Topstar, Topstar II and the Topstar 110 all came with pre-sheeted foam wings and stab (very nice, I might add). The Topstar 110 was available with either all wood horizontal surfaces or pre-sheeted foam horizontal surfaces. I have an all wood Topstar 110 kit, but it doesn't look like I'll ever get the pre-sheeted foam version.
By the way, great build thread and excellent work so far... looking forward to the flight report
-Will B.
Old 02-08-2011, 03:09 AM
  #140
dhal22
Thanks Will. You do have a nice MK collection if I remember correctly.
Old 02-08-2011, 05:05 PM
  #141
dhal22
ORIGINAL: doxilia
Nice servos David!
David.
David, if I remember correctly I penciled a sloped lines down a 2" pieces of aluminum angle stock. the angle stock was my straight edge perimeter around the wing. I kept the leading and trailing edges clamped to the lines.
Old 02-08-2011, 05:14 PM
  #142
dhal22
I am setting up the aileron servo boxes by taping below the wing skin before they're glued. Since the servos are surface mounted I will cut away the balsa skin just where the servos fit and replace with ply. That should give me something solid to mount the servos to after i finish the plane.
The wing skins are a pleasure. already cut to fit and they fit perfectly. just a matter of gluing them on which I am doing now......
ID:	1560487   Click image for larger version
ID:	1560488   Click image for larger version
ID:	1560489   Click image for larger version
Old 02-08-2011, 06:54 PM
  #143
doxilia
doxilia's Avatar
Got it. Nice approach. Thanks.
Man, MK does make a nice sheeting...
What's up with the retracts? Got those in?
David.
Old 02-09-2011, 03:19 AM
  #144
dhal22
David, the retract mounts are in but need to finish the details.
Old 02-09-2011, 02:48 PM
  #145
Avaiojet
David,
Great job!!
Third photo. please explain that gap?
Old 02-09-2011, 04:20 PM
  #146
frequent flyer
David
Great job, glad to see the build is back under way!
Old 02-10-2011, 03:03 AM
  #147
dhal22
ORIGINAL: Avaiojet
David,
Great job!!
Charles, the wing sheets would be too wide to fit in the kit box if the 2 pieces were one piece.
Old 02-10-2011, 05:14 PM
  #148
dhal22
I'm thinking about using 3" heavy duty cardboard tubing for retract wheel wells. It's fairly lite, so far .80 of an ounce each but i will have to glass the insides. I also found a tube of some sort at Mcmaster Carr that i will use for the strut paths. It also is very light. At least I have a plan though.
ID:	1561423   Click image for larger version
ID:	1561424   Click image for larger version
ID:	1561425   Click image for larger version
Old 02-10-2011, 06:36 PM
  #149
Rendegade
.80 of an ounce?! I've built entire aircraft that weigh less than that!
Old 02-10-2011, 06:41 PM
  #150
dhal22
I could sand the outside of the tube pieces and get them down to a 1/2 oz.
