old timers look here must be 50+ years only
#1901
Only stands to reason that new engines would improve their performance over the older engines back in the day. Look at the improvements in radios over the same period of time. The improvement has it advantages when you a building a kit designed back when the older engine designs were state of the art.
#1902
George / Flyerinokc
What you say is true but it has been my experience that though a engine has the rpm an HP rating they don't produce the torque needed to achiecve the pulling power desired in many instances (exceptions accepted) I would have to put them to the test..... I have these engines.
If time permits I will conduct a flight test. I know the os 25 fs to be a pretty stout engine.
The weight differeces also produces balance problems that has to be compensated.
#1903
George / Flyerinokc What you say is true but it has been my experience that though a engine has the rpm an HP rating they don't produce the torque needed to achieve the pulling power desired in many instances (exceptions accepted) I would have to put them to the test..... I have these engines. If time permits I will conduct a flight test. I know the os 25 fs to be a pretty stout engine. The weight differences also produces balance problems that has to be compensated.
http://www.clstunt.com/htdocs/dc/dcb...25005&page=289
Good number swear by Fox .35 Stunt. Engines choices there are considerable variances.
Agree with you factors, weight balance, torque, propping correcting, fuel and glow plug affect outcome. A lot of preferences out there. My comments are academic. Would like to move up from 400 sq. in. profiles to 500 sq. in. full body or profile, got a Dykes ringed Testors McCoy.40 Series 21 Black Head begging for an airframe.
#1904
Donny, by coincidence another post just appeared on Stunt Hangar with good info on engines for the Nobler, Are we overpowering our Noblers?
http://stunthanger.com/smf/index.php/topic,41158.0.html
And a little off topic, but preparing for a little seasonal joy, too on tenor sax (video).
https://drive.google.com/file/d/0B7T9-FMCHtgJY2RKOXgzNWdKdTA/view?usp=sharing
#1905
#1907
#1909
MO
you guy's looking for some new in box engines at lower prices than discount houses or some low use used engines, need to contact me. i am 86 & will not get around to using all these engines,os max k& b greem heads enyas & more. [email protected] for list. look in to it! frankie
314-781-7409
NEW ENGINES
FREE SHIPPING ARTICLES OVER &100.00 & UP
314-781-7409
NEW ENGINES
Last edited by trainermaster80; 11-12-2015 at 04:49 PM. Reason: LEFT OUT SOME INFORMATION
#1910
I am very careful when I read such threads, one does not know all the parameters involved with he flight of anoters plane. isn't the arf nobler designed for a 25-35 size engine???? so what is it doing with a forty in it??
Many times when I got involved in this type of situation (discussion) I find the lack of knowlege to be the problem and when explained it gets all buggered up. in most cases someone did not take time to read the instructions especially when one ask am i over powering a plane designed for a twenty five with a forty in the nose.
#1911
I am very careful when I read such threads, one does not know all the parameters involved with the flight of another's plane. isn't the arf nobler designed for a 25-35 size engine???? so what is it doing with a forty in it??
Many times when I got involved in this type of situation (discussion) I find the lack of knowledge to be the problem and when explained it gets all buggered up. in most cases someone did not take time to read the instructions especially when one ask am i over powering a plane designed for a twenty five with a forty in the nose.
You have some purists who disdain any design that doesn't fit the idea stunt pattern plane mode, rants about wing thickness, etc. Then someone won this summer a high level stunt contest with a less than optimal legacy Ringmaster. Piloting skill trumped others on that one.
Got the wood, I'll need to start working on my 1960 Berkeley Interceptor 35, has same proportions as the Ringmaster but with thicker wing. Photo of box below shows the 15, but mine is the 35.
With a short nose, will balance better with a heavier engine. Don't know if I'll go with my K&B .20 Sportster or McCoy .35 Red Head.
#1912
I know you are talking of different types of airplanes, but I over power all my planes because I live at 6800 ft here in Wyoming, all my forty sized plane's get 55 and 60s some even has a 75, the 60 sized plane's get 90 on up to 108 and a couple with 120s, 40 size engines won't fly a 40 plane here, I had one on a trainer got it in the air using all 600 feet not fun way under power, when I go to Colorado or some parts of Wyoming like Worland and it's under 4200 I have a blast with the power!
#1913
At least for control line, flying on shorter lines of say 60' the effect isn't quite as pronounced and to maintain same lap speeds one goes to adding a little nitro to the fuel and experimenting with prop sizes.
#1914
Hi all, I`m Wullie, an old timer from bonnie Scotland and very slow typer! Born feb 1951 so retiring soon. Started with balsa/tissue/dope Keil craft rubber kits in 1962 or so,also some small balsa boat kits, airfix plastics before. Used to watch (in awe) r/c fliers on nearby council playing fields. Lost interest when 16 or so. Back in to boats (r/c) briefly between 1997-2000. Found,( dare I say it ) Hobbyking in 2012 and have built (and destroyed) several planes since.I also enjoyed shooting and fishing over the years and have had around 10 dinghies and motors to date. However, after almost 50 years as a joiner my back is giving me trouble so time for something less strenuous . Looking forward to enjoying this forum.--Wullie.
#1915
Hi Wullie and welcome to the gang. However, you're just a youngun...lol I got you beat by about 13 years or so but still having fun in this modeling world... Currently have a scratch build of my first (1956-57) RC plane (Mambo) on my build list. Also, recently took an interest in a boat due to one of the threads on here. Started and am going along slowly with my scow build. As I know very little about building model boats, it's going along slowly but I'm enjoying the trip....
Hope all is well with you and yours,
Don
Don
#1916
Off topic but someone over in the Saito asked my Saito didn't have their own website, well they do.
http://www.saito-mfg.com/english/top.html
#1917
Don
Don
#1918
MO
hey wullie, keep a bottle of alive handy & get out to a model field ,watch & talk to the modelers. lots of comaradere is good for your spirit. i know i am 86 & still flying although i am building my last giant scale airplane a DYNAFLITE SUPER DECATHLON. GOT THE TAIL FEATHERS & 1/2 OF THE WING ABOUT 1/2 FINISHED.STILL FLY A SIG SENIOR KADET & SIG 4 STAR 120 WITH SUPER TIGER 2500. IT'S PRETY FAST & AEROBATIC. I HAVE BAD BACK TOO.
SO THERE WULLIE HANG IN THERE. FRANKIE TRAINEMASTER 80
#1919
Hi Frankie. Hope I can still see a plane when or even if i become an octogenerian! Guess that`s 21/2 metre span then. Have the greatest respect for you guys, I get upset when I crash a 1.4m cheapo foamie.--Wullie.
#1920
Posted here a while back as a retired carpenter ,only 60 ,retired at 55 .lol Been flying / building for over 35 years .I also enjoy hunting down plans online and building them also , FREE plans only and sharing them by giving builders here the sites where i find them at . Took me 7 years to find the PL-12 Airtruk on page 2 but plenty of others on the 4 pages. joe http://www.foro-aeromodelismo.com/vi...p?f=22&t=11223 If i can figure out how to download them anyone can trust me .lmao joe
#1921
Here is a link to a laser cut short kit with the plans!
http://store.laser-design-services.c...roducts_id=210
#1922
I just downloaded two plans from the site you posted. I am a sucker when it comes to free downloads. as a scratch builder collecting plans is a must though I won't live to build them all I am having a good time! here is one I downloaded sometime ago It's from keil kraft plans and was a fun build I will mold a canopy soon.
Shaun the sheep
welcome! this thread is becomeing a world traveler .......I like that!
#1925
