old timers look here must be 50+ years only
#2451
Here I go with my first post in this thread.
Observation #2. I know why Geezers like large planes. I took my 10-20 eyesight for granted until it was no longer 10-20. Heck, I'd settle for 20-20 with glasses. It's getting harder to see the orientation of my smaller planes. I told my wife recently I would not buy anything new under 80" so her half of the garage was in jeopardy. That did not go over as well as I had hoped!
Cheers
bob T
#2452
SLEC Fun Fly. 54" (1372mm) wingspan. OS 40 FP up front. Just Engines Super Quiet Silencer, I hate noisy engines! Plan to maiden this and the Gemini later today.
The Gemini is a copy of the first r/c model I ever built; it was not a success in 1988 owing to an inexperienced pilot! The modern manifestation is powered by an electric motor retrieved from a couple of electric foamies. Same goes for the servos and the undercarriage. The original had a tricycle under carriage but there was insufficient space in the nose to allow for both the motor and the nose leg.
Wish me luck!
Wish me luck!
#2454
A new monster BGX engine was up for sale at the clubs cubs and cousins air show at a gimme price but when I thought of the fuel consumption I declined, that thing could consume a gallon of two stroke fuel in two flights.
I just got into large two-strokes myself. A Moki 2.1 on an 80" Edge. I got 8 eight minute flights out of the first gallon. Not nearly as bad as I feared. Besides, 5% nitro is a lot less expensive than 15%
#2456
Wish me luck!
Good Luck!!
Wish me luck!
Good Luck!!
#2457
Bisson Pitts Muffler O.S. 40SF/46AX/50SX/55AX
$39.95
http://www3.towerhobbies.com/cgi-bin...&I=LX8680&P=ML
#2458
I like the colour of your Gemini , how does it show up in the sky ? I have the 110 Rascal and am betting the 14ft. one will be fun as long as field prep isn't too bad .When is it expected ? I wonder if a G62 would fly it ? I have a spare one of those kicking around . You will probably need a full size pickup or a trailer to transport it . I have a 12 ft. Cub on floats and it just fits into my truck . What's that thing that looks like a padlock just behind the canopy on your Slec Fun Fly ?
#2459
Hi Biker BC!
I regret that the weather has been a bit too windy to permit test flying so I can't answer your question about how the Gemini looks in the air. It is covered overall in Fluorescent Yellow Solarfilm.
As for the "padlock" that's simply a piece of ply with a small hole drilled in it and a screw which holds down the rear of the canopy to the fuselage. I found it very difficult to understand the instructions relating to canopy so I've secured the front with two magnets and have used some velcro midships too. It should stay in place.
Judging by your handle, you are a motorcyclist. This is mine.
http://i1143.photobucket.com/albums/...int%20ST_1.jpg
#2460
#2461
Hi Biker BC!
#2462
They designed the new 168 to be able to fit in a minivan. The tail is removable so all you have is that skinny part of the fuse to slip between seats, or through the rear window of the cab, which in my case, I have a topper, so should be easy. The center wing is 6', and that could be a challenge with my 5'5" bed. The G62 should fly it perfectly, I am looking to use an FG-57 Twin, which is a gas Saito 4 stroke. With the two servos in the outer wing, two servos in the center wing, that would be the only connections, but I am not sure how the outer wing panels attach to the center. I doubt it would take very long to setup, maybe 10 minutes. All depends on what you have to set it up on. I most likely will trailer it with the rest of my planes when I do a full day of flying, so will have a table with me, and on those days I truck it, I can use a run up stand, though will probably need to bring a screw drill and screws to extend the tail end of the stand.
#2463
Hi Donny, I didn't like to fly the biplane with the Super tigre 2300 because of the $20+ / gallon fuel. Now I buy $3/gallon methanol I get at a local drag strip. I mix in 10% castor oil. I mix 10% castor oil and 10% synthetic 2 cycle oil for the Satio FA-100, the OS .25 and the K/B .28. I mix 30% castor oil for the Fox .35 and Torpedo .19. I don't miss the nitro at all.
#2464
Zero and low nitro fuels are not easy to find around here but when it is found the price is high so mixing my own is a positive alternative.
#2465
Maidened the Gemini today! It did not require any trim adjustments!
I was really surprised as I don't consider myself to be a particularly good builder. Throttled back to half power it flew well. I was anticipating it to be much faster. I did a few circuits loops and rolls then decided to land.
I'm not a particularly good pilot either, and stalled the model just before landing, wiping off the Foam-E WOT 4 undercarriage; it was only held on by two wood-screws. There was no other apparent damage, the C of G seemed to be within limits so I hand-launched it and flew it about before landing it on the grass.
Guess I'll reinforce the undercarriage plate and bolt the undercarriage on with nylon bolts. That way I could easily fly the model either with or without the undercarriage. I'll also make a few cosmetic alterations.
Thirty years on, I've succeeded in building and flying my first radio controlled model aircraft again.
Mission accomplished!
#2466
#2467
I am breaking a promise not to build anything new but I didn't want to miss the oppurtunity to build myself a copy
these will be numbers 2 and 3. I got several parts copied and cut out and found a new set of spring air retracts in my stock pile.
#2468
Outstanding choice!!!! Great plane!!!!!!!!
#2469
Pleased to report that the maiden of the SLEC Fun Fly was successful. It was a bit windy so I flew the ARTF Stick 1500 first as I don't really mind if I crash that one!I managed quite a long flight with a landing on the 10 metre wide runway, however, I clipped the prop on landing and filed a few millimetres off one of the blades. Then I faffed about watching others fly, thought about flying the Gemini instead, thought about not flying the Fun Fly but finally decided that I was a competent enough pilot so off I went.
The take off didn't go in the direction I'd planned but I soon got hold of it. It required a fair bit of up trim and a small amount of left aileron but after that I just flew it about on low rates most of the time. Loops, rolls, immelmans, (immelmen?) even a Cuban Eight, then I decided to quite while I was ahead. I brought her in somewhat hesitantly and on finals I heard Fabrice, the club's treasurer, who had just arrived, shout out, "Sur la piste!...Sur la piste!" which means, "On the runway!" I'm pleased to say that I put her down on the runway, without clipping the prop and taxied her back to me. It was not my best landing ever but it was a maiden flight and there was no damage; better than some of Fabrice's later landings with his Goldberg Piper Cub! Then I flew the Gemini and managed to land that on the piste, again, it was not a perfect landing but I'm still getting used to this model too.
I got Roger to take a couple of pictures of your humble servant posing with the model in my NCB suit which matches the colour of the model! I'm going for a haircut and beardtrim on Tuesday. I may even dispense with the winter whiskers, they make me look like a badger or a homeless person!
Perhaps I'll opt for an aviator's moustache!
#2472
#2473
National Coal Board.
They date from the time when we had a coal mining industry. Today there's not a single underground coal mine in the entire of the UK. That's why the overalls were cheap.
Some of my former colleagues in my English club called them my "Guantanamo Overalls!" I don't care! They're very well made, they keep me warm, they keep my clothes clean and they're fire resistant. They might come in useful some day, you never know!
#2474
National Coal Board. They date from the time when we had a coal mining industry. Today there's not a single underground coal mine in the entire of the UK. That's why the overalls were cheap. Some of my former colleagues in my English club called them my "Guantanamo Overalls!" I don't care! They're very well made, they keep me warm, they keep my clothes clean and they're fire resistant. They might come in useful some day, you never know!
#2475
...also if anyone were to crash their model into me while I was wearing them, I would be able to sue them quite successfully.
As for hard hats and reflective vests, I'm pleased to say that those days are behind me.
I also have a red set but I've never worn them...
