Go Back  RCU Forums > RC Airplanes > Crash & Rebuild
Reload this Page >
Aeroworks 50CC Mustang Rebuild
Crash & Rebuild Post your crash stories, pictures and if you want to document your rebuild you can do that here too!
Old 01-14-2014, 02:36 AM
  #51
Lifer
Lifer's Avatar
Thank you for sharing all of this! I always replace the wooden dowels with the correct size aluminum rod glued in with JB Weld. Stronger, and no issues with vibration-induced wear. Hope this helps someone.
Old 01-14-2014, 06:41 PM
  #52
ctshepherd
My Feedback: (34)
ctshepherd's Avatar
Thanks for comments guys! I've gotten to a point on the fuselage where I wanted to start covering... there is still some work to be done around the cockpit and cowling areas so I have started at the tail. I am using silver Ultracote for the fuselage and the blue on the rudder is Oracal sign vinyl.
Started covering the bottom of the fuselage.
For the rudder, I ironed on Ultracote around the perimeter and then applied the Oracal sign vinyl. In the second pic, you will see that I am using the backing paper from the Ultracote to heat up the Oracal to make it softer and conform to the edges of the rudder. I also used this method also when I applied the Oracal to the trailing edge of the rudder.
Next up was the fuselage sides...
Mounted up the cowling to mark out where the blue will go. Put a strip of the silver Ultracote centered over the line that will be where the silver transitions to the blue. Still have a bit of work to do on the cockpit as I need to come up with material to make up the instrument panel hood.
Until next time...
ID:	1957799   Click image for larger version
ID:	1957800   Click image for larger version
ID:	1957801   Click image for larger version
ID:	1957802   Click image for larger version
ID:	1957803   Click image for larger version
Old 01-17-2014, 02:05 PM
  #53
ctshepherd
My Feedback: (34)
ctshepherd's Avatar
More covering work today on the fuselage. Laid down the rest of the silver on the front portion of the fuselage. Ironed down a strip of silver down the centerline of the front deck so that when I purposely did not butt the blue perfectly together it looked like a panel line with a small bit of silver showing through. Blue does not match exactly, but it is close enough for the guy on the galloping horse not to notice when it flies by at speed.
Almost done with the fuselage covering, just have the vertical stabilizer left to do. I will be ordering markings from Callie Graphics for Petie 3rd and the nomenclature decals from IFlyTailies. Plan on doing some panel lines and weathering to give it that "in service" look.
Until the next update...
ID:	1958847   Click image for larger version
ID:	1958848   Click image for larger version
ID:	1958849   Click image for larger version
Old 01-18-2014, 08:28 AM
  #54
Fly2XS
My Feedback: (65)
Fly2XS's Avatar
Inspiring work Mr. Shepherd!
I'll send some appreciation.
Old 01-25-2014, 05:54 PM
  #55
ctshepherd
My Feedback: (34)
ctshepherd's Avatar
Thanks Scott, much appreciated.
Not much happening lately on the Mustang as it has been a little chilly in the garage. Latest pictures... Installed the aileron and flap servos and pinned the firewall. I will be spraying the firewall with texture paint once it warms up a bit.
ID:	1962117   Click image for larger version
ID:	1962118   Click image for larger version
ID:	1962119   Click image for larger version
ID:	1962120   Click image for larger version
ID:	1962121   Click image for larger version
Old 01-25-2014, 06:48 PM
  #56
hookedonrc
hookedonrc's Avatar
I know what you mean about the cold. Usually we have some pretty mild Winter months, but lately my garage and the Pulse 125 I am assembling has not seen me much. I will say the 51 is looking very nice, hope for better weather.
Old 01-25-2014, 07:10 PM
  #57
rt3232
Pikers its been -10 to -20 below hear in flyover land of corse I have a well insuladted and heated/ air conditioned shop when needed.
Buy the way a realy nice rebuild
Cheers Bob T
Old 01-26-2014, 05:57 AM
  #58
SWORDSN
My Feedback: (13)
Cheers Bob T
It's no wonder you guys up North are such good builders,that's about all you can do in the winter. I have been trying to paint a fuse for three weeks,but it has been too windy or too cold or both!
Old 01-26-2014, 12:40 PM
  #59
StAndBl
StAndBl's Avatar
Minnesota is a builders heaven if you have a heated shop in the winter!
Old 01-27-2014, 12:19 PM
  #60
Fly2XS
My Feedback: (65)
Fly2XS's Avatar
Shepherd is from way up north in North Carolina.
I heard he has a heated shop as well!
Old 01-27-2014, 12:51 PM
  #61
SWORDSN
My Feedback: (13)
Yeah I know,,just north of me.There are some good ones down South too.They say the snow is coming here tonight.
Old 01-27-2014, 05:55 PM
  #62
ctshepherd
My Feedback: (34)
ctshepherd's Avatar
When you find the heat, let me know! I do have a small heater that I have tucked under my table, but it does not do much other than take the chill off in the garage(shop).
Old 01-27-2014, 06:09 PM
  #63
rt3232
Well just add to your misery we have so much cool air we are sending it south as we don't what it any more wind chills hear @ 30 to 40 below, gouund blissards and black ice
cheers Bob T
Old 01-28-2014, 11:51 AM
  #64
SWORDSN
My Feedback: (13)
cheers Bob T
Bob, I don't think I would last!
Old 01-28-2014, 02:59 PM
  #65
ctshepherd
My Feedback: (34)
ctshepherd's Avatar
Thanks for the cold air.. it is now mixing with moisture coming up from the Gulf and producing white stuff that sends the people around here into waves of panic and causes school cancellations before even the first flake hits the ground.
Back to the Mustang, the graphics from Callie's came yesterday, so I spent some time putting some panel lines on the fuselage by indenting them in with a pencil. Here are a few motivation shots...
ID:	1963004   Click image for larger version
ID:	1963005   Click image for larger version
ID:	1963006   Click image for larger version
ID:	1963007   Click image for larger version
Old 01-28-2014, 05:30 PM
  #66
rt3232
ctshepherd
That re build is realy looking great.
sorry about derailing your thread with the weather thingy
cheers Bob T
Old 01-29-2014, 05:26 AM
  #67
ctshepherd
My Feedback: (34)
ctshepherd's Avatar
ctshepherd
cheers Bob T
No worries on the weather derailment! I am ready for winter to be over already. School cancelled here for the second day due to snow.. all 2" of it. It appears they just don't know how to deal with it here. Cold today, so I have moved my table in from the garage into the house so I can get some things done on the mustang in more favorable temperatures.
Old 01-29-2014, 07:09 AM
  #68
SWORDSN
My Feedback: (13)
ctshepherd
cheers Bob T
Me too!
Old 01-29-2014, 01:33 PM
  #69
ctshepherd
My Feedback: (34)
ctshepherd's Avatar
Due to being off work today thanks to my kids having a snow day, I moved the work table into the house so I didn't freeze my you know what off in the garage. More work on the fuselage putting on the graphics. The plane is really starting to look good with some color on her. Pics below of today's progress.... First three pics show the fiberglassing of the foam part that I shaped to replace the damaged wing filet. I stuck down some press and seal, then used double sided tape to stick the piece of foam to that. Mixed up some epoxy and brushed it on the foam, laid some fiberglass cloth over the epoxy and then brushed some more to fill the weave. Not the greatest looking thing, but I suppose it will do after I putty it up to make it match the remaining piece a little better. BTW, no need to apologize for anything... feel free to discuss anything plane related here. The weather applies, because we need nice weather to fly and right now there is not much of that happening around the country!
ID:	1963251   Click image for larger version
ID:	1963252   Click image for larger version
ID:	1963253   Click image for larger version
ID:	1963254   Click image for larger version
ID:	1963255   Click image for larger version
ID:	1963256   Click image for larger version
ID:	1963257   Click image for larger version
ID:	1963259   Click image for larger version
ID:	1963260   Click image for larger version
Old 01-29-2014, 02:17 PM
  #70
rt3232
I like pic's better than words
Cheers Bob T
PS 2inches ? we have 15 on flat ground and 5 or 6 ft. in piles
Old 01-29-2014, 02:59 PM
  #71
ctshepherd
My Feedback: (34)
ctshepherd's Avatar
Yep, 2" and the place practically comes to a standstill. People just don't know how to drive in the stuff around here...
Old 01-29-2014, 08:15 PM
  #72
StAndBl
StAndBl's Avatar
This rebuild is looking good! I'm watching closely. Hoping to start a kit over next winter, so i'm looking for techniques and anything I can try. It'll be my first kit build.
Off topic a bit, I used to live in SC, the one time I remember getting snow they shut EVERYTHING down on base. My parents laughed at people trying to drive, they're both originally from here in MN. Weatherman is cursing us with a possibility of 5 more inches tonight.(with around 13 inches in my yard already).
Anyway, keep up the nice work!
Steve
Old 01-29-2014, 08:53 PM
  #73
abbott915
Just found your thread, and all I can say after reading through and looking at the images is, . . . WOW!!
FANTASTIC JOB!!
Old 01-31-2014, 06:17 PM
  #74
ctshepherd
My Feedback: (34)
ctshepherd's Avatar
I will let the pictures do the talking... black stripes applied.
ID:	1964197   Click image for larger version
ID:	1964198   Click image for larger version
Old 01-31-2014, 06:23 PM
  #75
ctshepherd
My Feedback: (34)
ctshepherd's Avatar
Steve
Thanks Steve. What kit are you looking to build?
