Is it rebuildable
#18. "RE: COMBAT CARNAGE IN TEXAS...?"
In response to Reply # 0
[TABLE="width: 100%"]
[TR]
[TD="class: dclite"]
[/TD]
[TD="class: dclite, width: 100%"]I am sure most all are familiar with the arrangement of the flying site at Muncie. Also that the site has a major high voltage transmission line running across the property over near the west edge.
A few years ago one of the combat flyers, Stubby as I recall, had a 1/2A model cut loose. It flew away dragging a lot of the lines. When it got to the power lines over near the HQs building, we saw a flash and a cloud of brown smoke, followed a few seconds later by the large bang. The model ended up in the lake out front, I was told.
I spoke to some folks who were working inside and they were totally unaware of it happening: didn't hear the explosion, didn't even flicker the lights.
[TR]
[TD="width: 100%"][TABLE="class: dcbordernew, width: 100%"]
[TR]
[TD][TABLE="width: 100%"]
[TR]
[TD="class: dcdark, bgcolor: #EEEEEE, colspan: 2"][TABLE="width: 100%"]
[TR]
[TD="class: dcdark, width: 100%"]Cowboystunt1[/TD]
[TD="class: dcdark, align: right"]Fri Nov-07-14 08:39 PM[/TD]
[/TR]
[TR]
[TD="class: dcdark, width: 100%"]Member since Sep 07th 2005
3642 posts[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD="class: dclite, colspan: 2"]#20. "RE: COMBAT CARNAGE IN TEXAS...?"
In response to Reply # 19
Fri Nov-07-14 08:42 PM by Cowboystunt1
[TR]
[/TD]
[TD="class: dclite, width: 100%"]As I remember it the incident occurred at the LAST Reno Nats and did shut down a large part of the City's electrical system for several hours.
I can't believe this really happened that many times!
The worst thing I'v seen happen here in Tucson with flyawayss was a cut away hit Larry Scarinzi's Rented Car in the parking lot, and that was after the shut off rule was in place!
How stories do grow in number
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[TR]
[/TD]
[TR]
[TR]
[TR]
[TR]
[/TR]
[TR]
3642 posts[/TD]
[/TD][/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TR]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
#33
My Feedback: (10)
John "sparky" Welsh earned his nickname by blowing a few transformers in north San Antonio 18 or so years ago. We were flying at the local high school and Bob Sawyer flew a couple passes through the high voltage wires. Not to be outdone john tried a pass, caught a wire, and the wire swung up and back and flopped it over the top of another wire after releasing his plane. BIG BOOMS followed as several transformers blew. Power went out, Plane was unharmed. John packed up and quietly left . A couple of days later John walked into the hobby shop and Bob gave him a hearty "Hey hows it going Sparky" as a greeting.
#34
I doubt I could duplicate that with year's worth of practice...!
I would never guess that the wires can be jostled enough to collide with each other.
#35
hey combatpig i saw a similar incident at a cl contest. after a kill flying combat flyer was doing figure eights trying to fly out the tank. somehow he let the handle go and instead of going straight to the ground the plane rose up with lines and handle dangling for a few seconds and then crashed
#40
7000 grains /pound
5 pound plane
35,000 grains
80 mph = 117 feet per second
result is 1064 ft lb force or 1443 joules, based on a projectile calculator. A more advanced calculator factors in the diameter of the "bullet".
It's amazing how any part of a model engine can survive this.
5 pound plane
35,000 grains
#42
7000 grains /pound
5 pound plane
35,000 grains
5 pound plane
35,000 grains
#46
Re-build (not this one) and fly again!
#49
L8's crash probably looked a little bit like this! By the way, the wing skins on an F-4 are over 5/8 inch thick, and there are numerous hefty baffles in the wing and struts to distribute fuel loads during high-G maneuvers. The amount of aluminum in that aircraft is mind boggling, but to see it turn to dust so fast is even more so.
http://www.youtube.com/watch?v=RZjhxuhTmGk
#50
7000 grains /pound
5 pound plane
35,000 grains
5 pound plane
35,000 grains
