Go Back  RCU Forums > Electric Aircraft Universe > E-Flight Power Sources
 battery question for a freeflight conversion project >
E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
Old 08-31-2004 | 12:21 PM
Default battery question for a freeflight conversion project
Got a quick battery question for you experts. Im currently working on converting one of those $15 guillows balsa kits meant for rubber flight into an rc plane using a gws pico flight pack. Anywho, its a fairly small plane with 24 in wingspan and a full fuselodge (not a stick). My question is, would there be any problem using a 6 cell 7.2 volt 900mAh battery in this little guy? Im guessing that would put me in flight for over an hour, its the same battery pack used in aerobird challenger, is there any obvious problems with using this battery? I saw some people who built a similar sized plane use a 6 cell 7.2 volt 230mAh battery in theirs, same battery setup, except its 670mAh less than the one I'd like to use. Any problems with using this battery in a smaller balsa plane?
Old 08-31-2004 | 03:09 PM
Greg Covey's Avatar
Default RE: battery question for a freeflight conversion project
The biggest issue with the 6-cell, 900mAh NiMH pack is weight. It is about 4oz.
Consider a 2-cell [link=http://www.hobby-lobby.com/thunderpower.htm]Thunderpower[/link] 860mAh pack that can deliver 8.5amps continuous and up to 13amps burst at only 1.5oz.
A 2.5oz weight reduction in your small plane makes a huge performance upgrade!
Old 09-09-2004 | 11:33 AM
VinceHerman's Avatar
What motor/prop/gearbox will you be using?
