E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
esc programming help
Old 10-28-2006 | 01:23 PM
Default esc programming help
I just went brushless and I am having problems programming the ESC. It says full throttle up , then plug in battery and you should hear a beep. then 5 seconds later another beep... but that never happens.. the three and one just flashes and never makes a beep. Help!
Old 10-28-2006 | 01:35 PM
Default RE: esc programming help
What type of esc, motor and radio?
Old 10-28-2006 | 01:57 PM
eflite as recomended in the manual..
Old 10-28-2006 | 02:27 PM
Hmmmmmmmm.
Make sure both the "Y" harness for power and "Y" harness for the servos are connected properly.
Should hear some sort of beep. If not, could have gotten a bad esc.
Old 10-28-2006 | 02:32 PM
it beeps once as I hook to batttery.. Eflite says it(ESC) is factory set "lipo on, brake off" which is what we want. so i bypass set up.... So then I pull stick down and hook to battery and wait for 3 in1 to initialize, but nothing happens. It beeps once then red blinks as normal but doesn't go green, just red and green. (((( 3 leads from motor to esc, lead from esc red wire pulled, plug into y harness, throttle lead from 3 in1 into other end of y harness, plugged harness into # 3, battery lead to 3in1, last lead into battery)))
Old 10-28-2006 | 04:41 PM
I'm stumped.
Old 10-28-2006 | 06:03 PM
Check if your throttle channel is reversed.
Old 10-28-2006 | 10:28 PM
BBCCONT, you da man! That was it ! thanks>>
