Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 problems taking off with training gear >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 11-11-2006 | 06:24 PM
Default problems taking off with training gear
Ok so let's rule out a couple of parts that have been replaced
Ball links
Main motor
Main shaft
Rear rotor
My heli struggles to get off the ground when I have the training gear on it seems. However with it off it seems to be alot easier to get off the ground. Aside from the above parts any other things I should check? I re-aligned my blade pitch it's now at 1-2 deg positive. in idle up mode with all trims centered.
I'm running the plastic blades (which I'm suspecting are too heavy)
If anyone of you have experienced such a problem with lack of power for take off please share.
Old 11-11-2006 | 07:21 PM
Heli_Harry's Avatar
Default RE: problems taking off with training gear
How old are the motors?
Old 11-11-2006 | 07:59 PM
DVI
If you are using the training gear, Do not use the idle up mode. Increase your blade pitch one turn at a time until you can lift off at about 3/4 throttle.
Old 11-11-2006 | 08:25 PM
plastic blades are probably too heavy if your not using lipo. Also are you at altitude? It is harder to get lift at altitude. I suggest going to lipo and getting rid of the plastics for now.
Old 11-12-2006 | 03:09 AM
Motors are 2 days old (replacements were put in because I suspected bad motors).
maybe the whole setup is too heavy with plastic blades, worst case I guess I could just throw on the CF ones but I'm still hesitant being still a trainer pilot.
Old 11-12-2006 | 05:59 PM
lwatson's Avatar
For training the wood flat bottom blades are better because of the weight. Keep it in normal mode, put your throttle trim to just under half way up. Pitch should be about 3-5 degrees positive with throttle in full down. Heli should lift off at about 60 percent throttle. If this doesn't happen, I might recommend upgrading your battery to a TP1320.
Old 11-12-2006 | 06:25 PM
check this out.... http://www.jcshobbies.com/setupguide.html it should help ya..
Old 11-13-2006 | 03:20 AM
actually today while taking it up with a friends he was also having troubles getting power from his glider motor. Could it just be that we're in canada and NiMH batteries can't take the near zero soon to be sub zero temps?
this would explain why both my heli and his glider were unable to get any altitude dispite being different systems.
Old 11-13-2006 | 07:52 AM
Vortex05
I have a Blade CP and have some input on this matter. I have found this heli to be greatly affected by the temperature outside. During an attempt to fly in 5 degree C conditions, the heli would lose head speed within 20 seconds and become unflyable. I have lots of experience flying electric planes in cold weather (all winter long) and know in this case it is not a result of the lipo battery getting cold. I think its possibly an issue with the 4 in 1 being used in a cold environment.
Old 11-13-2006 | 12:50 PM
This is interresting quick question are NiMH affected more or less by the cold cause that's what I'm currently flying with. Don't have the cash for a decent charger yet and flight season is pretty much over (due to cold) so I'm still on the NiMH packs.
