Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 Blade CP Pro Tail Question >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 03-26-2007 | 03:21 PM
Default Blade CP Pro Tail Question
I have just ordered a blade cp pro and have heard about numerous problems with the tail motor. I realize that i can either upgrade to dual motors or the gws dd system. But i would like to know if the gws dd motor would fit in the stock motor mount. Any help or advice would be appreciated. Thanks[8D]
Old 03-26-2007 | 03:53 PM
Default RE: Blade CP Pro Tail Question
I have heard of people using the stock mount, although you might have to modify it a bit so the round can fits in the hole that has flat sides. The GWS tail holder isn't too much money either, so you could get that and if the stock tail doesn't work, then you could go to the work to change it out.
Also here is a post I wrote up about the comparision of the different tail options if you're looking for something like that. I can't remember if I included brushless setup, but there is that also, it's just quite heavy. http://www.rcuniverse.com/forum/fb.asp?m=5553620
Old 03-26-2007 | 04:16 PM
If i were to upgrade to the gws motor, would it be necessary to buy the gws tail prop or just use the stock one?
Old 03-26-2007 | 04:40 PM
DVI
Check out May issue of RC Heli magazine. There's an artical on up gradeing the Blade CP Pro and he uses the GWS EDP-50XC tail motor & 3-2 prop on the tail and it fits right up to the original tail mount. Good luck with yours!
you will need the new prop. stock housing works fine, all you need to do is elongate the screw holes alittle.
