Blade CX folding blade big problems
I thought I would just jump in here. I am a newbie to all this. I ordered the entire Extreme core assembly for $64.95 for my CX2 about a week ago. I ordered it from "bladecx2.com". When it comes to my door I will install, test and give you guys a report. I also ordered the Extreme fly bar. I ordered the Xtreme boom kit and skid from ushobby.com, the skid is great because I am using a Thunder power 1320 mah battery. It fits like a glove in the skids with a little velcro.
After reading alot of post on just what are the best grips and hop ups I came to the conclusion that it was worth it for me to try the Extreme core. Just looking at how it is designed and the fact that it is mostly plastic I think is better. It seems to me to be more of a personal issue that people are having with the seller of the Extreme core rather than the parts themselves. Anyway I will find out soon one way or another. I will keep everyone posted.
Helibeli, The problem that I'm having is that I only bought the grips and blades. I also wanted to stay with plastic due to its light weight. I forgot where I read this but it was from one of the i-stores that said that these would work with stock e-flite parts. They are wrong and cause of this I believe give exteme a bad name. The guy at bladecx2.com was very helpful and if you ever have a problem just give him a call.
If you got the whole core then is should fly just great. I don't want extended shafts (i just don't like the look). I'm just looking for blade grips.
Hi All, I fitted the complete Extreme core and used Xtreme blades about 2/3 weeks ago - it works a treat, good hover and FFF.
However! the last couple of days the tail has developed a twitch when its in a stable hover - its as if its waging its tail like a dog. It moves about 1/2" clockwise then 1/2" anti-clockwise but fast??!! The twitching stops when I apply more power or move forward/backward/side-to-side.
It’s as if something is binding, I've checked both shafts and they are not too tight, the screws through the outer shaft don’t seem to be touching the inner. Shafts are straight and the blades and flybar are balanced and free moving.
I forgot which way up the washer on the bottom of the outer shaft goes (flat side down or flat side up?!) but I’ve tried it both ways and it does make a difference to the twitch.
Any ideas what could be causing it?! Bad bearing? Dodgy swathplate?
OK
I'm new at Helis. I bought a CX2, and practiced like the manual advises. After about 6 flights, i nicked one of the upper blade. Since then, whenever i hover the aircraft sways from side to side, and i immediteley land. Hovering is no longer an option. I tried adjusting the trim setting several X's. There are no visible broken parts. Any advice. Thanks
cutterboy - the cx has a built in rate gyro to hold the head steady when you are hovering, but cuts out when you move - sounds like the gyro gain is a little too high - this can happen when you change the weight of the heli - you need to adjust your gyro gain - it's in the manual - go slow and change by tiny bits, fly and see if its better
docnee - if you look at the heli from the side with the blades spinning fast but not quite at take off speed, you will see that the blades are probably out of track
http://www.heli-max.net/mediawiki/in..._and_CX2_Setup
edge
edge
#31
Thanks for advice cx2cp+, I didn't even give the electronics a thought. I'll try it and let you know how I get on.
#32
WA
I will have to make time I guess because I will not let this one go. The parts you can get them from helihobby and you do not need to buy the whole kit at once u can buy separate parts till you build it up. They are not that badly priced , i think???? I am going to get the mod motors. It should help.
#33
Taven, The owner of bladecx2.com(Extreme's manufacturer) Told me that the grips/blades are for spare parts for the whole core system. They weren't intended to be used with e-flight's assembly.
You can still try and if you get it all working together then let me know what I missed.
#34
WA
No, i mean i will just get the rest of the kit . The whole system from what we got is just , longer shafts , different gears. Look at helihobby.com . I know you said you did not like the look of the long shaft, but folding blades are sweet as I am you are sure.
#35
QC, CANADA
ORIGINAL: BryFlyGuy67
Return the "Extreme Core" stuff and get the "Xtreme" upgrades from either www.boomtownhobbies.com or www.ushobbysupply.com.
I have not used the "Extreme" products, but by all accounts hee on the forums in the last 6 months, it is crap. Sorry. [
Take the refund.
]Take the refund.
hi
all clients happy look at feedback on ebay
http://search.ebay.com/_W0QQsassZbladecxpro
if you have any problem real support is available
#36
QC, CANADA
ORIGINAL: eat2muchrice
if you have only SL52 it can still work but it is folding blade only
sold many all clients happy
most of the comon problem normaly is very simple
blades not tight or inverted number 2 is supose to be upper not lower, flybar is to stiff
those thing are easy to fix
real support on those link
http://www.bladecx2.com/forum/viewtopic.php?t=16
http://www.bladecx2.com/forum/viewtopic.php?t=6
http://www.bladecx2.com/forum/viewtopic.php?t=5
#37
Sonat, Nice to see you in here. I'm sorry that some people seem to be bashing your product. I'm sure your extreme product is great and I have heard of MANY good reviews of your products. I'm personally not into the whole extended shafts (looks) I want to keep a low style on my heli.
#39
QC, CANADA
want to make excuse for bad english writhing
and the time that I dont have to read all forum post and reply to thems
so crazy, many clients come back for more of our products
having clients worlwide over 5000 of thems
so little time on hand
will try to help at best, but the link
normaly solve all posible problem
if I miss something on the support, will make modification on our support page
this should help all customers
with our products
For those that like there heli so bad like we do
special link just for you
wallpaper for your computer
http://www.bladecx2.com/heligirls.html
p.s
to all that views this post, want to said happy XMass
and want also to give you a update on new real upgrades for 2008
new battery holder in developement durable light weight will be in white or black
it as been desing that you will be able to play with the position of your battery ( center of gravity )
this battery holder as cost us, at the moment over $20,000 in molds
very precise piece of plastic you have no idea
also racing canopy 2.0 ( crash resistant ) will come in red/yellow black window
or white with black window
as our goal is alway low weight and durable Upgrades and we specialise in the blade cx and cx2 only
those new part will be a new kik in the market
www.bladecx2.com
with our products
p.s
www.bladecx2.com
#40
Thanks for the advice Edge, I adjusted the gyro gain and the twitch has gone.
Like you said it's all in the manual - I think I should read the whole manual again, there's allot of information in there I simply missed or didn't understand when I first started.
#41
Thanks for posting on here "Sonat", and giving us an update on your new products. As I mentioned above I ordered your core assymbly ($64.95) and a fly bar a week ago. I got email confirmation and a tracking number for the Canadian mail, but I have not recieved it yet, and the tracking information never changes.
It just says "electronic informatin has been recieved on 11/29/07.
I live in Illinois, when do you think I can expect to see my new parts?
I can't wait to try them!
#42
QC, CANADA
ORIGINAL: Helibeli
hi
here info about shipping
because we are in canada sometime there is small dealy because box get inspected at the border
here some info that it is also in our support page about shipping
WE SHIP TWICE A WEEK.
ONCE YOUR ORDER HAS BEEN SHIPPED,
YOU WILL RECEIVE CONFIRMATION BY E-MAIL.
YOUR ORDER WILL ARRIVE IN 4 TO 16 DAYS
NOTE: OUR EXPERIENCE SHOWS THAT THE TRACKING NUMBERS
OF CANADA POST ARE NOT ALWAYS ACCURATE.
#44
WA
I bought my adjustable flybar from sonat off of ebay and I just figured that out. We both left pos feedback and if I remenber he thru in some FREE upper blades but they were the folding type and that is what set the damn rocket off to go folding. So go figure it came full circle. My be a inside joke.
#45
THATS NOT TRUE I USE XTREME PARTS AND HAVE NEVER HAD A PROBLEM WITH THEM I BUY ALL MY PARTS FROM BLADECX2.COM AND SONNY HAS ALWAYS BEEN THERE FOR HELP!!!!!! WHY DOSE SO MANY PEOPLE HERE TALK BAD ABOUT SONNY PRODUCT?
#46
Probably because a lot of people have tried them and have been unhappy. Maybe bad customer service. I don't know.
By the way DO NOT SHOUT unless you really mean to. I did.
#47
Also, please be clear. We are talking about two different products with similar names (Extreme vs. Xtreme)
Xtreme products (some of them, anyway) are pretty good. I've never tried the other at the advice of MANY, MANY people both here, on HeliFreak and on RC Groups.
If someone wants to give me an "Extreme" setup for free, I will be happy to install it and provide an honest opinion. Until that happens, or the reputation of the Extreme line gets much better, I will stick with what I have.
#48
WI
ORIGINAL: sonat
http://www.bladecx2.com/heligirls.html...
#49
I JUST INSTALLED ONE OF THOSE EXTREME CORE UPGRADES FROM BLADECX2.COM AND I'M HAVING THE SAME PROBLEMS. I'M TAKING IT OFF AND SENDING BACK WETHER I GET A REFUND OR NOT. THIS IS THE SECOND TIME I BUY FROM THE CANADIAN. THE FIRST TIME I GOT SO FUSTRATED I SOLD THE HELI. THIS TIME I'M THINKING ABOUT IT TOO. BOOMTOWNHOBBIES, EXPECT A PURCHASE FROM ME SOON.
#50
ORIGINAL: JREQ
If you had problems before why would you buy from Canada again?
The Xtreme blade grips that Boom Town Hobbies carries are the best ones on the market and work great.
