E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Kicking up problems...
Old 01-30-2008 | 10:16 AM
Default Kicking up problems...
Hi my ef sabre is kicking up problems yet again after i fixed them only last night, but this time it is straying to the left on take off. All parts of the heli are intact but i was low on both heli and transmitter batteries could this be the problem please post solutions to my problems!
THANK YOU!!
Feel free to add pics of your helis i would love to see them or links of videos to you flying them that will be great 2!!
Old 01-30-2008 | 10:19 AM
stump3r's Avatar
Default RE: Kicking up problems...
These FP machines always go left on take off. I find that if you hop them into the air and give a little right aileron you can catch them. Takes a little practice but you will get it.
Old 01-30-2008 | 10:22 AM
Lol it might be that but normally it will just take off straight up!
But this time its kinda sliding to the left as i throttle up []
Old 01-30-2008 | 10:26 AM
stump3r's Avatar
Most if not all of them slide left, is the centrifugal force of the blades. Mine lifts straight off now, but it's only because I'm inputting to correct it without even thinking about it now. Once you get her in the air if she is still moving left you might have a trim issue.
It's a lot of reading but this thread covers almost everything for a FP machine http://www.rcuniverse.com/forum/m_6807677/tm.htm
Old 01-30-2008 | 10:30 AM
Ok thanks
Old 01-30-2008 | 08:45 PM
Like stump3r said, it's a blade thing - and that tail rotor. The rotor pushes left because the heli wants to spin right. On ice, the tail rotor will push the heli across the pond just trying to keep the tail from rotating. In the air, looking from behind, the heli does not fly level. It leans right to counter the other forces. Trim your heli so when you let go of the sticks, the heli does not travel sideways out of control. Neutral stick must be neutral flight input. The heli will not hover unaided, but the trim should be set so neutral stick allows the heli to 'rest' with minimal wander. Once I got mine trimmed that way, I actually started to hover it!
Big Happy,
Soloboss
